09-14-2013, 03:33 PM | #1101 | |
Vintage Evil
Re: 68 S/C update.....
I was looking at the same paddle shift setup... let me know what you think when you get it...
09-16-2013, 06:04 PM | #1102 |
Spent the past few days reading this entire thread. Just started my search for a '67-68 swb and wanting to do something very similar. Unfortunately I doubt I will have the same budget but I love everything you have decided to do. Can't wait to see the results of the new combo.
As with quite anew others, I'm taking a lot of notes. Posted via Mobile Device |
09-20-2013, 11:18 AM | #1103 | |||
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-20-2013, 10:35 PM | #1104 |
All I can say is WOW! I thought this truck was killer with the 383 and blow thru carb but now its insane. Great work cant wait to see it finished.
09-24-2013, 09:12 AM | #1105 | |
Well, no real good pictures, but some real good progress this weekend (thanks again Ernie!). tranny lines plumbed and aux cooler mounted inner cooler and pump mounted and plumbed radiator back in and hoses connected fuel system plumbed (fuel pressure regulator, injectors and rails mounted) new driveshaft ordered from DSS http://www.driveshaftshop.com/domest...ece-driveshaft Speartech EFI harness in place and about 75% wired AC wiring connected about 75% complete ac system leaked checked and ready for freon (way to go Ernie! ) TwistMachine ShrifterSix paddle shifters sitting at Speartech for bench testing.... http://twistmachine.com/index.php?ma...products_id=39 I still have a lot of loose ends to finish, but the elephant is getting smaller....
09-24-2013, 09:42 AM | #1106 |
Amazing progress Rob. This thing is gonna be sick.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
09-24-2013, 11:58 AM | #1107 |
Nice update Rob!
-Rus |
09-24-2013, 12:28 PM | #1108 |
You might have mentioned before but what are you looking hp and ftlb?
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
09-24-2013, 04:07 PM | #1109 |
Thanks!
Thanks! Hopefully 600+...
09-24-2013, 06:06 PM | #1110 |
Way to go Rob She gitt'n dun!
09-24-2013, 09:24 PM | #1111 |
Sweet, lookin good
09-25-2013, 09:25 AM | #1112 |
Thanks Bill!
Thanks! Here's a couple of pictures of the ShrifterSix paddle shifters, !
09-25-2013, 05:12 PM | #1113 |
Are you having to use a shorter column for that to fit or does that unit take place of the column adapter?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
09-25-2013, 06:29 PM | #1114 |
It replaces the column adapter.
09-25-2013, 10:54 PM | #1115 |
paddle shifter !!!! sweet !!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
09-26-2013, 08:22 AM | #1116 |
Formerly- 1972SuperCheyenne
That is sick! Cant wait to see it installed.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
09-26-2013, 08:48 AM | #1117 | |
Thanks! It should be pretty sweet with the 6 speed auto. Thanks!
09-26-2013, 11:22 AM | #1118 |
The paddle shifter looks great Rob, I can't wait to see a video of this truck tearing up the streets
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
09-26-2013, 12:06 PM | #1119 |
Vintage Evil
09-26-2013, 12:12 PM | #1120 | |
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-26-2013, 12:21 PM | #1121 | |
It's a stock column. I may have to "tweak" it a little.
10-04-2013, 08:18 PM | #1122 |
I apologize for the minimal updates, but it seems like the less time I spend on here, the more I get done, .
I finally got enough wiring done on my install so I could at least test the Dakota Digital VHX gauges. After a few trial and errors (mostly errors, ), I got everything working!!!! Using the VHX gauges and along with the OBDII BIM-01-1 interface, I'm able to pull just about everything the CAN BUS monitors AND display it on my gauge interface, everything from the check engine light, speed, tach, water temp, oil press, tranny temp, IAT, OAT (I'm not sure how that's working???), and I even got it to display the gear indication!!!! I'm extremely happy right now and I can't wait to fire this bad boy up, . I also figured out a way to wire up the BIM so you don't have to jam up your OBDII port. Let me know if you want the info. Sorry for my exuberance, but it was a banner day on moving my build forward. I received the drive shaft (beautiful piece!), and if it weren't for having to update my pinion yoke to accept a 1350 u-joint, I would have gotten it installed (should be here Monday). Sorry no pics, maybe tomorrow, just wanted to share my excitement.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-04-2013 at 08:23 PM. |
10-04-2013, 08:47 PM | #1123 |
Rob man you have done a beyond of an outstanding job on this truck. I also cant wait to see the video of it specially the inside of the cab shot...
Congrats!!!
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-04-2013, 08:51 PM | #1124 |
Thats an awesome update!
-Rus |
10-04-2013, 09:10 PM | #1125 |
A day late and $1 short...
Keep it rollin' bro!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
