12-19-2011, 10:47 AM | #126 |
Re: 68 aka "Chained in Porterbuilt Prison"
Oh, I'm very interested in the hood. Would like pic when you get a chance. Thanks--Dave
68 Chevy SWB Stepside--under construction--now Fleetside w/18's & 20's--getting ready for 350 TPI motor w/700r4 67 Camaro--17x8's and 19x12's--C5 & Airride Technologies susp. (not finished) 09 Tahoe--lowered w/20's Superformance Cobra--347 stroker w/Weber injection--polished 17's--SOLD 08 Scion Xb w/ground effects and 19's (son's car) |
12-19-2011, 10:48 AM | #127 |
67cheby
one other question , i notice the top of the fender to bedside area is open and then the bottoms of the inner bedpanel to bedsides are capped, just thinking out loud but if you are driving in the rain are the tires going to throw water up into the bedsides and then will it be trapped ? or is there drain holes we just can see ?
12-19-2011, 11:29 AM | #128 | |
If it doesn't work like I think-I can always go back and cut that 4-5* angle into the tub at top and have it butt like stock tubs instead of flushing inside.........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
12-19-2011, 11:35 AM | #129 | |
12-19-2011, 11:56 AM | #130 |
67cheby
LOL, that makes sense , i figured you had thought of the water issue just checking in case you hadnt .
12-19-2011, 06:25 PM | #131 |
I knew u had my back!!! Back on the dash this week--trying to get bedsides done to bolt back together cause wheels are do in 2 wks-trying to get backspacing perfect to narrow rearend-U can do all the figuring U want but nothing better than putting bed down over tires &wheels and measuring between-Can't mess up that way!!That's why all the work on inner panels-I'm anal about tire to wheel lip distance and also look how crisp the new wheel well lip is without the inner spot welded to it--Only going to do this once!! this is the wheel...........20 x 8 1/2 and 20 x12's
http://driverzinc.com/product/schott-mod5/
12-19-2011, 06:30 PM | #132 |
67cheby
nice !!
12-19-2011, 10:18 PM | #133 |
See if these give a better look at tub layout-Mike u can see where tubing stops above marker lite-no reason to extend further and it gives water relief!!
Also would allow me to do this gas filler trick if i wanted--probably not though-when finished the cap was to be body color and perfectly flat...........jim
12-19-2011, 10:21 PM | #134 |
pics of gas filler on last truck--PITA to do but slick............jim
12-19-2011, 11:51 PM | #135 |
67cheby
nice !
12-20-2011, 12:08 AM | #136 |
C/10 junkie
That is slick.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
12-20-2011, 02:00 AM | #137 |
VA72C10
That's my #2 favorite gas filler mod besides huggercst's I believe rear light gas filler mod? But I was going to do like above because I wanted to run the LED taillights with the billet trim and they wouldn't work with the taillight filler mod.
Looking for a 67-72 swb or blazer project in or around VA. |
12-20-2011, 10:36 AM | #138 |
Here's the link to it if U ever want to use ----But I found it somewhere else cheaper----------same part.............jim
http://www.bmschoppers.com/eshopprod...h_Mount_Po.htm
12-20-2011, 11:51 AM | #139 |
PROJECT 7DEUCE
Figured id jump in on this build thread...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-20-2011, 03:01 PM | #140 |
VA72C10
I actually found one on ebay a while back when I was planning this mod. Have the exhaust pipe for the bottom bend and the stake pocket...just never got around to finishing the project I intended it for.....some day!
12-23-2011, 11:08 AM | #141 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
12-23-2011, 06:21 PM | #142 |
explain the design on the hinge-maybe I missed a thread---I like alot.....jim
12-23-2011, 07:06 PM | #143 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=380571
12-23-2011, 07:46 PM | #144 | |
12-29-2011, 11:23 PM | #145 |
A little update---still working on body panels with a bodyman buddy of mine who is having rough time financially --He is working panels before he has to give up his shop!! Nate sent me a late Christmas present with this rear cab panel kit (just layed in for now) Also got my front 14" grand sport rotors and dropped spindles from Boris (way2lo) Thanx guys!!
Hey Mike--(67 cheby) My wife says "your NOT going to cut that perfect fender (in epoxy) for those big ol' tubz are u"??? I said "with your permission" one of these days!!! LOL She just walked out of shop shaking her head!! She didn't see where I had cut this gaping hole in a perfect door for bearclaws in between body work!!.................Ya'll all have a good new year!!!................jim
12-30-2011, 12:15 AM | #146 |
6>8 Plugless........
Awesome work! Love the tail gate mod too! The fenders may be much, but once you did it and the truck was done, may be pretty awesome I think!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
12-30-2011, 12:17 AM | #147 |
awesome work man!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
12-30-2011, 12:32 AM | #148 |
Tell U how crazy I am--I have probably 6-8 extra fenders-been thinking about cutting my bodyman buddy loose on one and rough in body work just to see!! just bought a flawless pair of valve covers off ebay---I think once installed it would freak people...........we'll see..............jim
12-30-2011, 12:39 AM | #149 |
Nothing else, it'll be bad azz garage wall art!!!!!!!!!!!!!!!!!
12-30-2011, 12:39 AM | #150 |
VA72C10
Looking really good!!! And some GREAT parts!!!
