Old 01-13-2014, 07:11 PM   #201
theastronaut
theastronaut's Avatar
Re: 1966 F100 Short/Fleet Full Stock Resto Build Thread
Originally Posted by duallyjams View Post
Great looking result after a 10 month journey, getting excited to watch it go back together.
Me too, I'm itching to start bolting parts on it!
theastronaut is offline   Reply With Quote
Old 01-13-2014, 07:14 PM   #202
theastronaut
Picked up the cab and doors this morning. The factory primer color underneath was red oxide with tan overspray around the edges, so we sprayed the bottom with PPG DPLF epoxy to match the original primer. We'll do the overspray pattern tomorrow using single stage.
With primer on it, you can see how much effort we spent smoothing the weld seams on the rust repairs.
Old 01-14-2014, 10:50 AM   #203
aggie91
I'm just glad to be here!
aggie91's Avatar
looking good!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-14-2014, 09:04 PM   #204
theastronaut
Stayed late tonight to spray the bottom of the cab with the factory style overspray pattern around the edges. We had single stage color matched for this since base/clear wouldn't have the same effect. I didn't have anything to go by, other than one post I found that said that the bottom of the firewall wasn't masked from the factory, just that the paint was solid until the last roll at the toe boards. Hopefully it's close to how the factory "painted" the bottom of the cab.
Also shot the column parts, hinges, and front cab mount covers.
Old 01-14-2014, 09:10 PM   #205
theastronaut
Originally Posted by aggie91 View Post
looking good!
Thanks Karl!!
Old 01-14-2014, 09:59 PM   #206
plainred65
plainred65's Avatar
As always your work is truly an inspiration, always checkin in on your work.
plainred65 is offline   Reply With Quote
Old 01-15-2014, 06:02 PM   #207
theastronaut
Appreciate that!!
Started wetsanding the cab today with 1000 grit. Marked all the edges with a sharpie marker so we could see if we were sanding around the edges too much. That keeps us from sanding through, or getting it too thin and burning through with the buffer later on.
Old 01-15-2014, 06:32 PM   #208
CG
BlahBlahBlah
Geeze I love looking at your builds ... If you think ya need a little more practice, Ill send you over my 62 Unibody =)
Old 01-16-2014, 09:24 AM   #209
Low Elco
Looks great! Imma steal that Sharpie trick. Is this wetsand for final clear, or polish?
Low Elco is offline   Reply With Quote
Old 01-21-2014, 05:58 PM   #210
theastronaut
More updates. The flywheel cover was pretty beat, looked like the clutch disc had exploded at some point! We straightened it, blasted, primed, and painted it.
Inner fenders wetsanded and painted.
Emergency flasher switch bracket blasted, painted, and the clip polished.
Door hinge springs were blasted and painted. Used a ratchet strap to pull the coils apart so they got fully painted.
Horn ring assembled and installed on the wheel.
Old 01-21-2014, 05:59 PM   #211
theastronaut
Couldn't find a decent radiator support so we ordered a reproduction and used the bottom half to repair the original RS.
Marking the cut lines.
Cuts cleaned up, making a template using masking tape.
Took measurments of various points so we could align the template, then stuck it on and sprayed silver paint to mark the cut line on the new RS.
Initial fit up of the two pieces.
After final fitting, welding, and smoothing the welds. Really surprised at how well the two pieces fit together.
Old 01-21-2014, 06:02 PM   #212
theastronaut
Lol thanks, we're a little rusty on some of this...
Thanks! It's for wetsanding before buffing, use it when wet blocking the clear flat with 1000 grit on a long/skinny Durablock. Then switch to dry powder guide coat and 2000 grit on a soft pad. Any sharpie marks left over get buffed off.
I explained the process in more detail here:
http://67-72chevytrucks.com/vboard/s...d.php?t=519043
Old 01-22-2014, 07:37 PM   #213
theastronaut
Guide coated the cab with powdered charcoal before wetsanding with 2000 and 2500 grit today. The charcoal shows all the 1000 grit scratches, so we can be sure we sanded all of them out with 2000. It also won't stick to non-sanded paint so it shows any spots we missed.
After sanding with 2000 and 2500. We'll buff it tomorrow and hopefully have it back on the frame by Friday.
Old 01-22-2014, 07:43 PM   #214
NONHOG
NONHOG's Avatar
More stuff I've never heard of.
Awesome!
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 01-23-2014, 06:19 PM   #215
theastronaut
Awesome!
Hey, if it works, it works. And I didn't pay $40+ bucks for 3M dry guide coat, only cost about $5 bucks.
We bolted the cab back on the frame today after buffing it. I'll post pics soon.
Old 01-24-2014, 01:42 PM   #216
shok
Where do you get this powdered charcoal?
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 01-24-2014, 04:41 PM   #217
theastronaut
I buy it a hobby/art stores like Hobby Lobby. Comes in stick form and has to be ground up; I use a 2 or 3" air grinder with a worn-out 80 grit disc held over a paint cup.
Old 01-24-2014, 04:42 PM   #218
theastronaut
Cab is buffed and bolted back on the frame.
Old 01-24-2014, 04:58 PM   #219
shok
Nice trick!
Old 01-25-2014, 11:29 AM   #220
jhrusk
Truck looks awesome, never thought I would enjoy looking at a F**d but the skills you guys have are really neat to see.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 01-28-2014, 09:33 AM   #221
theastronaut
Tires mounted, used Firestone 7.75's bias plies from Coker.
Old 01-28-2014, 10:14 AM   #222
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Wow! I wish I had that amount of attention to detail as you all do! I am way to ADD to pay attention to anything very long that is naked.....just saying
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-28-2014, 10:15 AM   #223
theastronaut
Thanks dudes! jhrusk, we'd rather be working on a Chevy too...
Old 01-30-2014, 06:19 PM   #224
theastronaut
Scored a few NOS parts on ebay, those showed up today.
Kick panel vent.
Upper E-brake cable.
Inner/outer window wipes.
Windshield rubber w/groove for trim.
L&R vent window seals.
Took the radio face plate apart to have it rechromed and to restore the lens/background plate.
Lens had scratches that needed sanding out.
After wetsanding and buffing.
Lens wrapped with tape to protect it, and the background was restored with a decal that came with the gauge restoration decals.
Dome light before/after blasting and painting.
Old 01-30-2014, 09:19 PM   #225
BlueJeep
BlueJeep's Avatar
Looks fantastic as always.
Do you spray all of those little parts with a gun or with a spray can?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
