Old 11-09-2012, 02:20 AM   #51
tallic68
Active Member
Re: LS factory cruise control hook up
Dose anyone know where I can get one of these? I've searched every pick-a-part in the area and nothing. I found the right year/ model w/cc but all levers were gone. I've got a later style modified with a single screw mount but I'm not happy with the look. To bulky.
tallic68 is offline   Reply With Quote
Old 11-09-2012, 04:07 AM   #52
ls1nova71
ls1nova71's Avatar
If it's looks you're after, I have what you're looking for if you have a.67-72. I have a few "hybrid" levers that I've made from different parts that match the turn signal levers on 67-72's. They have the grooves in them. Or i have the newer looking ones tht are smooth. I can post some pics later today.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-09-2012, 05:26 PM   #53
tallic68
Active Member
Sounds good.
Old 11-09-2012, 08:39 PM   #54
ls1nova71
ls1nova71's Avatar
I almost forgot about the pics, and I don't have alot of time right now, so I couldn't find the good pics, but here's one of them on my truck. I have the ribbed kind and the smooth kind, both these pics are the ribbed. The smooth are $45 shipped and the ribbed are $50 shipped.
Old 11-10-2012, 11:17 AM   #55
Daaaanz67
Are these compatible with ls dbw also are the ribbed one the period correct for the 67/72
Daaaanz67 is offline   Reply With Quote
Old 11-10-2012, 12:52 PM   #56
ls1nova71
ls1nova71's Avatar
They work for the gen 3 engines, the gen4 are harder to get cruise to work on. Also... they're not period correct, they just look a little more correct, especially if you have a tilt since they match the tilt lever.
Old 11-10-2012, 07:26 PM   #57
Daaaanz67
My drive train came out of 06 Tahoe dbw will this work
Old 11-10-2012, 08:25 PM   #58
ls1nova71
ls1nova71's Avatar
Yes it will, the engine in my orange truck is an '06 as well.
Old 11-10-2012, 10:23 PM   #59
Daaaanz67
I'll take one of your best ribbed one I'll pm you.
Old 11-10-2012, 11:21 PM   #60
cjohnson6772
cjohnson6772's Avatar
Is there anyway to fish this down through the column without taking it all apart? Factory tilt. Also, any chance we can get a pic of where the wiring comes out of the lever?
cjohnson6772 is offline   Reply With Quote
Old 11-11-2012, 08:25 AM   #61
mcmlxix
Collector of Projects
mcmlxix's Avatar
The cable from the stalk is flat and should be able to fit... with a little finess...
Rich
1972 K5 Blazer CST Click HERE
Old 11-11-2012, 10:41 AM   #62
Hart_Rod
Hart_Rod's Avatar
Great information! I've got two trucks I have to do this to....
Hart_Rod is offline   Reply With Quote
Old 11-12-2012, 10:53 AM   #63
Daaaanz67
Ls1 nova did you get my pm
Old 11-12-2012, 11:18 AM   #64
ms2335
ms2335's Avatar
I will take a smooth one if you have any left. PM me Paypal info
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 11-12-2012, 12:14 PM   #65
ls1nova71
ls1nova71's Avatar
Just got it, PM sent.
I don't have anymore ready to go at the moment, but will in a few weeks. If you're not in a hurry I can let you know when they're done
Old 11-12-2012, 12:24 PM   #66
ls1nova71
ls1nova71's Avatar
You would need to pull the turn signal switch out, well, not all the way out, but take the three screws out move the switch out of the way, put the column in the straight position, take the little wire cover that goes between the shift bowl and the dash off, then you can fish the wire down it fairly easily. The wires on the cruise switches are pretty rigid, so it's not all that hard.
Here's the pic of where the wires come out of the lever.
Old 11-12-2012, 12:55 PM   #67
ms2335
ms2335's Avatar
Thanks! That is fine just put me in line.
Old 11-12-2012, 02:14 PM   #68
Clyde65
Clyde65's Avatar
Ls1nova71 helped me get my cruise up and running perfectly with the stalk, connectors, brakes switch and all the diagrams to get it working, very helpful guy! I can't say that enough.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-12-2012, 02:15 PM   #69
aggie91
I'm just glad to be here!
aggie91's Avatar
Great thread. I sent you a PM about a lever also....
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-13-2012, 02:16 AM   #70
Daaaanz67
Payment sent for ribbed one
Old 11-25-2012, 02:50 AM   #71
Daaaanz67
Just got back in town and got the package man that lever looks brand new money well spent thanks. Just got to get it hooked up thanks for labeling the wires also.
Old 11-30-2012, 05:00 PM   #72
Dads Burb
Does the column have to be from a truck? I have 2 columns I would like to do this on. One is from an 80's Buick or Olds with the key in the column and the big bulge and bulky looking cruise lever on it. The other is from an earlier Buick. It also has the key in the column, but it has the older style column look and the cruise lever just has a button on the end (I guess to turn it on) and I think it only has one wire coming from it.
My engine and harness is from a 2004 Tahoe (flex-fuel) with 4L60E trans.
I would really like to use the older style column, but I want the cruise functions of the newer column. Would one of your levers work for me in this column?
I hope this made sense.
Dads Burb is offline   Reply With Quote
Old 11-30-2012, 05:49 PM   #73
ls1nova71
ls1nova71's Avatar
There are different styles of levers. The int you say is bulky, does it have four wires? If so it will work. If it doesn't have windshield wipers in it, its probably a 3 wire, but you can swap the switch inside the lever out with a newer switch. The older column with the single button can be made to work, but you would have to wire the cruise to be on at all times when the ignition is on, and you would only have the set/coast feature, no resume/accell. If you want all the features to work you would need a newer switch like the ones I have. I have the kind that screw in with a single screw, like your older column, and also the push in type for columns without wipers built in.
Old 11-30-2012, 05:57 PM   #74
Dads Burb
Thanks for fast reply. The newer column doesn't have the wiper controls. I need to look at it closer and see if it has all the cruise functions and how many wires it has. I know the older column only says Cruise with 1 button at the end.
The older column is the one I would like to use. I will check them and get back to you.
Old 01-02-2013, 03:25 PM   #75
Hart_Rod
Hart_Rod's Avatar
I have a HND-3 from Dakota Digitial.
http://www.dakotadigital.com/index.c...prod/prd50.htm
How will it work with a 2006 DBW? I installed the handle on a Flaming River tilt column and it was a PITA to get the wires pulled through....
