Old 01-27-2016, 02:34 AM   #1
longorange68
ECE static lowered, soft ride
Put ECE's 3.5/5 inch drop kit and disc brake conversion on my 1968 C-10 long box. Stance is great! Drove it around with the 235/75 15's on all 4 corners and the front dives and won't settle out after bumps in the road. Sometimes it is bad enough to get the tires to rub the inner fender wells which will pucker you up in a hurry!!
It came with the lowered KYB shocks and is softer than I'd prefer. Did I set something up wrong? I'm not super familiar with lowering vehicles, but this one was straight forward and I had a friend who'd used ECE kits in the past help me out. Running a smallblock and a 700r4, so it's not that heavy. What gives?
1968 Chevrolet C-10, 2WD, Longbox, Vortec 350, Monster Transmission 700R4, 3.73 gears
Good judgment comes from experience, and experience, well......that comes from bad judgment.
1968 Chevy C-10 "Longshot": Bought used from my Uncle George in 1994 and proceeding to beat the hell out of it for 4 years. Sold it. Bought it back, dumped an ungodly amount of money into it since then.
longorange68 is offline   Reply With Quote
Old 01-27-2016, 06:45 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: ECE static lowered, soft ride
Shocks.
Some like the ride cushy some like it firm.
I imagine it's hard for ECE to please everyone with their kyb shocks.
Did you talk to them before you ordered?
I suggest a new set of performance shocks.
QA1 or RideTech.
Do you have any pics of your truck?
Keith
Convert to disc brakes.
Old 01-27-2016, 11:53 AM   #3
PGSigns
PGSigns's Avatar
I had the KYB's on my 66 and did not like them. Went to the Bell tech street performance shocks and they are much better.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-27-2016, 01:01 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
My personal recommendation is Bilstein.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 01-27-2016, 02:33 PM   #5
longorange68
Stiffer shocks seem to be the consensus. Does that mean on all 4 corners or just the fronts? Would a sway bar firm things up as well?
Old 01-30-2016, 09:58 AM   #6
Hart_Rod
Hart_Rod's Avatar
I would just do the shocks in the front and a sway bar will help stiffen everything up.
Hart_Rod is offline   Reply With Quote
Old 02-02-2016, 10:01 AM   #7
GEARBOXGARAGE
Which KYB shock did you use? ECE offers 2 different ones. The GR-2/Excel-G's are a more soft riding shock, the White Gas-A-Just are a stiffer shock for more of a performance feel. As stated above, there are better shocks out there, but will come at a cost. Bilsteins are great if you want a non-adjustable shock, or go with a QA1, Ridetech, or Hotchkis has some new shocks out that are supposed to be fantastic, which we will be going to very soon.
GEARBOXGARAGE is offline   Reply With Quote
Old 04-15-2016, 10:29 PM   #8
layinrocker65
layinrocker65's Avatar
Mind posting a pic of that wheel/tire combo?
‘53 GMC COE stock
‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘
'70 Chevy C10 LWB 350/sm465
‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags
layinrocker65 is offline   Reply With Quote
Old 04-16-2016, 12:37 AM   #9
Crushkrew
Crushkrew's Avatar
We run the ece 4/6 kit and had the same problem with the bouncyness...installed cpp sways front and rear and was better but still too mushy...solution was viking shock upgrade all around...double adjustable for the price of single adjustable...great USA quality and amazingly adjustable...couple clicks here and there and good for whatever the conditions and driving situation...
71 C10: Crush10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=650510
Crushkrew is offline   Reply With Quote
