Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain > LSx Related
Old 12-29-2016, 09:33 AM   #1
glueman
In a tight spot
Need some help........
Any recommendations on the best headers to use on LS2 with rack and pinion steering? Using a 3 knuckle steering setup. The DD shaft will need to run between the header tubes and the inside of the frame. Installed Hedman's with 1-3/4 diameter mid-length tubes. These do not provide enough room for the DD shaft to pass. Has anyone experienced this issue?
The Glueman
________________________
1967 C10 Shop Truck
1967 Nova
1968 C10
1972 Blazer
glueman is offline   Reply With Quote
Old 12-29-2016, 11:02 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: In a tight spot
I will have this moved to the LSx Swap forum. I think you will have better luck. I know a couple of guys have used the rack & pinion setups....
I used these on my '67 Chevy Panel Truck and they have quite a bit of header to frame clearance. I can measure the distance if you want me to....
http://www.ebay.com/itm/Hooker-Heade...xTxRxO&vxp=mtr
LockDoc
Leon
Old 12-29-2016, 11:07 AM   #3
Hart_Rod
Hart_Rod's Avatar
Re: In a tight spot
2010+ Camaro manifold work really well.
Hart_Rod is offline   Reply With Quote
