Insulating Suburban
Whats everyone done to insulate there suburbans from sound and heat. I have entire interior our and might as well do something prior to reinstalling
The Older Generation
Re: Insulating Suburban
Right, wrong, or indifferent, I sprayed the inside of my Panel Truck with 3M "Body Shutz" undercoating then used 2" pink foam board on the sides and 1" white foam board on the roof interior. I couldn't believe how much it quieted that tin can down.... ![]() LockDoc
![]() Join Date: Apr 2005
I used FatMat.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Yes, I feel it does. I used 4 or 5 rolls, (50 sqft/roll), but I doubled it on the floor and firewall.
Post Whore
![]() Join Date: Feb 2016
I used 2- 50 sq ft rolls of B-quiet mat on the steel floor and firewall. Then some foil backed bubble wrap on the roof. On the floor in back I have a 3/8" felt carpet pad under the carpet. I may still add some more insulation on the sides one I get some miles on it. I know it helped even with the few miles I have on it. Plus during the installation I discovered a spot on the roof that drummed like thunder with just a light tap of the finger. Replacing the window felts also made a huge improvement. If you want more info my WMB thread has some starting about page five.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#7 | |
Post Whore
Did you get the first set? That is good to know I know someone local who is looking for one. Thanks to Richard2717 for giving me a good used one I was able to get my glass installed last year.
how did you attach the foam board to the sides
#10 | |
Post Whore
If they followed through with your input and your high standards of quality they will be perfect.
If you are going to use side panels you don't need to attach it. The panels will hold it in just fine. LockDoc
#13 |
member
Contact Rick at "Raam Audio". I usually mind my own business and don't usually do referrals, but.... This owner, " Rick ", is probably one of not only the friendliest but very knowledgeable people about the products he sells . Call all the others that you want first , Then call Rick ! His prices are great too!
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
#14 |
Post Whore
I think I need to apologize for Hart_Rod and I hijacking this thread. I hope no one has been offended.
#15 |
![]() Join Date: Mar 2012
I used Lizard Skin.
One coat of sound insulation and one of heat insulation. I went from the top of the firewall to the wood floor and the entire roof. Took 2 gallons of each. |
#16 |
Here's the floor.
#17 |
Lizard Skin ^^^^^ How did this work out? Noticeable?
1968 C-10 Suburban - Original 396/TH400 2002 Transam WS6 - M6 - Black/Black - Evil Garage Queen 2000 Silverado - DD - Small lift+Body lift+35" Duratracs+4.88's + Eaton TruTrac - Monster Truck 2010 Cadillac CTS Wagon Sport - Wife's DD and the only classy car we have. |
#18 |
I don't know yet. I'm going to start it for the first time today.
#19 |
Post Whore
Still waiting for those updates.
#20 |
![]() Join Date: Nov 2015
Got my burb painted, put the new wood bed I made in Saturday and on this insulation step now. Putting a dynamat/fatmat type insulation on the steel floor.
Lizard skin is good for roof and sides/doors but expensive, they sell one for heat and noise reduction. One of the biggest perks of working in the high end restoration business for 10+ years I learned a lot from the actual vendors where they developed their products. For my 74 mini clubman race car I made before the burb I used a latex paint/insuladd combo since all I had in the interior was seats and a rollbar and it helped a ton. Lizard skin and all the other companies sell you a premixed formula. Look at insuladd.com and see the benefits. Be wary of amazon and eBay they sell a replica version and it doesn't work as well. Bought the insuladd heat and a gallon of generic paint for a 1/4 the price. Made it extra thick and coated the inside roof, sides, and doors yesterday. Putting in some foil backed styrofoam on the roof and frp panels/trim lock I got from Home Depot. ![]() ![]() ![]() ![]() |
#21 |
Post Whore
Thanks for the Insuladd tip. Did you use Azek for the new floor? Your Burban is looking good. Great color choice!
#22 |
Used regular pressure treated plywood, 2 coats of primer and 2 coats of paint. None of my local hardware stores carried a single sheet big enough so I bought two and joined together. Wood is joined together with a half lap splice, just used the old one as a template and drilled all the same holes. Went in a lot easier then it was to take it out.
#23 | |
![]() Join Date: Jun 2016
Thanks! |
#24 |
I'm about to install the doors as well from gmcpaul. Also have the rear cargo door and window and the super expensive long rear glass gaskets hopefully they all go in smooth.
#25 |
Post Whore
Once again I hijack this thread. PRP is Precision Rubber Products. They have redone their window seal for the third door fixed windows. HartRod worked with them on the new version and if he is happy then the seal is correct. It sounds like you have the old version. HartRod has pictures of the new ones near the end of his Superburban build thread.
