06-12-2008, 03:01 PM | #51 | |
Re: Dropmember Rear 63-72 Spy Pic
As for towing... I would not recommend towing with frame that has been notched.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
06-12-2008, 03:09 PM | #52 | |
A guy with a truck
Will the inner notch cap be one piece or two? It appears that the upper portion is left open- where the notch rests on the axle tube when aired out. The two pieces here with the stubby little ratchet:
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 06-12-2008 at 03:14 PM. |
06-12-2008, 03:50 PM | #53 |
The notch pictured had not yet been "finished"... the bottom portion you are referring to is welded in as part of the notch, along with with the two top plates that bolt to the top side of the factory frame rails. Due to the contour of the chassis I use a factory frame as the "jig"... I will be cutting this frame in half shortly so my "jig" won't take up as much space!
06-12-2008, 04:17 PM | #54 |
WTB this ad
Sweet!
06-12-2008, 04:26 PM | #55 |
On the fast track to nowhere..
Awesome!!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-12-2008, 04:44 PM | #56 |
You're going to cut up that fine TX frame?
06-12-2008, 10:49 PM | #57 |
Due to the sentimental value of this particular "TX frame" I figured I would immortalize it and make it the fixture for the 63-72 Dropmember Rear!
06-12-2008, 11:03 PM | #58 |
I'm sure my neighbors miss it..... .
06-12-2008, 11:30 PM | #59 |
great work like always. do you tig or mig when building the notch
06-13-2008, 12:04 AM | #60 |
Thanks for the kind words. I use the MIG process on all the plate steel.
06-13-2008, 11:41 AM | #61 |
Wow, that's gorgeous Nate.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
06-14-2008, 10:03 AM | #62 |
WOW great welds !!! Is there any reason this will not work on a lwb.
nickle and dime |
06-15-2008, 12:57 AM | #63 |
PorterBuilt Man Crush
Mine is a long bed, and I will be running it.
The 72 will live again |
06-15-2008, 10:07 AM | #64 |
nickle and dime |
06-23-2008, 03:34 PM | #65 |
Ttt
nickle and dime |
06-23-2008, 05:57 PM | #66 |
Lookin really good..... those are some very very nice welds...
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
06-23-2008, 09:44 PM | #67 |
Dang it! If I don't stop looking at this thread, I'm going to end up cutting a big hole in the rear of a perfectly good suburban...............
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-23-2008, 11:46 PM | #68 |
one way to make a "perfectly good suburban" even BETTER!
06-23-2008, 11:51 PM | #69 |
06-24-2008, 01:39 AM | #70 |
3DrDwn--the 'burb not the band
+1
I think my personal feelings on the subject are no secret. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
06-24-2008, 12:40 PM | #71 |
A guy with a truck
Worked for my ''perfectly good'' Blazer!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-24-2008, 01:29 PM | #72 |
Whaaaaa? Rear DM for the Blaze?
06-24-2008, 03:59 PM | #73 |
A guy with a truck
Nah. Don't count out the p/u though...
06-26-2008, 01:01 AM | #74 |
Finally have it 99% buttoned up.
A couple changes include: -Upper bag mount/bridge favors the 73-87 kit. -Rear four-link bracket is a weld on piece. Sorry for all the guys hoping that this would be 100% bolt-on, as I had originally intended. In order to get the link bars as close to the chassis as possible (for larger tires) I found it necessary to remove the trailing arm perch fron the axle tube and weld the bracket in place. The bracket is a two piece design, one bracket welds to the axle tube, and the other bolts over it and incorporates the four-link mount, bag mount, and shock mount. I made it modular in order to have some flexibility for fine tuning it with rvarying ride heights and or shock combos.
06-26-2008, 01:27 AM | #75 |
I don't have any trouble setting pinion angle myself but, Will there be some sort of locator once the old perches are removed or will this be a get out the measurin' stick and angle finder type of set-up?
just curious cause the magnet on my angle guage fell off and broke the guage so I'll get another if need. Josh
