Old 09-30-2009, 01:14 AM   #1
Ackattack
Ackattack's Avatar
CPP modular spindles
Well it seems that the CPP "bug" may have bitten me.
I was going to install my new CPP modular drop spindles. I set them on the ball joint, and they're clearly not the right size. Both the upper and lower holes in the spindles are too large. I guess I'll be calling CPP tomorrow to remedy the situation (hopefully).
I'm guessing they sent me a set for a different year.
Additionally, the LS1 camaro brake calipers simply won't work with the stock size rotor Now I have to find another set of calipers....grrrr
Ackattack is offline   Reply With Quote
Old 09-30-2009, 01:55 AM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: CPP modular spindles
I'd be hesitant to blame them right off the bat. I'm curious as to what ball joints they require?
texanidiot25 is offline   Reply With Quote
Old 09-30-2009, 02:17 AM   #3
leddzepp
Moderator
leddzepp's Avatar
What year(s) are your ball joints for?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-30-2009, 09:47 AM   #4
Ackattack
Ackattack's Avatar
My ball joints are for a 72. I removed the ECE drop spindles that work fine to install these. When they didn't fit, I measure the opening, and the CPP holes are clearly larger.
Old 09-30-2009, 09:52 AM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Good luck to you. I have avoided CPP due to simular post. Hope they make it right.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-30-2009, 12:12 PM   #6
Custom 68
Custom 68's Avatar
I will watch this too, I know they make them for different year ball joints, I wonder which ones they sent you. I dont know which are larger from year to year.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 09-30-2009, 12:33 PM   #7
68Stepbed
68Stepbed's Avatar
Well, I'm pretty sure the 63-70 ball joint holes are larger than the 71-72 units. They may have sent you the 63-70 disc conversion spindles instead of 71-72. Hopefully they're not just made wrong.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-30-2009, 12:36 PM   #8
Ackattack
Ackattack's Avatar
OK, so I called CPP and they're sending me new spindles.
Initially they wanted to not pay for me to ship back the incorrect spindles (even though they messed up), but I was able to convince them to pay for it (~$45ish for shipping).
They were trying to tell me that it was past the 30 day return policy (sorry my truck was at the paint shop for 4 extra months!!!!)
Oh well, looks like they'll make it right.
Old 09-30-2009, 01:11 PM   #9
70rs/ss
70rs/ss's Avatar
63-70 ball joints are smaller than the 71-72's been there and done that, so they sent you a spindle for who knows what?!
70rs/ss is offline   Reply With Quote
Old 09-30-2009, 01:26 PM   #10
Hart_Rod
Hart_Rod's Avatar
Sounds like they sent you the 73-87 HD spindles. What did you do with the ECE spindles?
Hart_Rod is offline   Reply With Quote
Old 09-30-2009, 01:32 PM   #11
Ackattack
Ackattack's Avatar
Nothing yet.....Frizzle Fry has already contacted me about buying them though.
Old 09-30-2009, 01:35 PM   #12
Hart_Rod
Hart_Rod's Avatar
Let me know what FF says. I am going to buy a set today or tomorrow....
Old 09-30-2009, 03:51 PM   #13
Frizzle Fry
Frizzle Fry's Avatar
Look at Rob always sniffin for a deal Me too! I say I want them if he's sellin them (at a reasonable price).
Thanks for remembering that Ack. It's been a while...
Frizzle Fry is offline   Reply With Quote
Old 09-30-2009, 03:54 PM   #14
Hart_Rod
Hart_Rod's Avatar
, Looks like you beat me to it. I'm getting ready to buy some from Stan at ECE. I really needed the ones from a 73-87 anyway since that's what I've already bought the bushings and ball joints for...... Are you going to put these on Tubby? I didn't think you could get it any lower????
Sorry for the HiJack Ack....
Old 09-30-2009, 05:37 PM   #15
Rreemo
Rreemo's Avatar
Sorry I didn't post on this one before....I just now saw it. I ran into the exact same deal on my old 72' with the CPP spindles. They use the 73-87 ball joint with them. In my situation I was planning to change the ball joints while I was there anyway, so it all worked out. It's not a bad thing though, the 73+ ball joints are a little tougher, and the major bonus was that I found they were close to half price of what the 71-72 were.
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Rreemo is offline   Reply With Quote
Old 09-30-2009, 05:53 PM   #16
Ackattack
Ackattack's Avatar
Acording to the information on the Modular Drop Spindles, no modifications are required, hence why they're listed specifically for 71-72.
Maybe their older regular drop spindles require ball joint changes. I bought and replaced my ball joints when I put my chasis together and really don't want to change them out since they have 0 miles on them.
Old 09-30-2009, 08:22 PM   #17
bigguy69
dazed and confused
bigguy69's Avatar
i bought a set for a 70 chevy truck. i didnt have any problems with them fitting. i did however have problems with the calipers. i could not get them to quit leaking. i ended up going to autozone. then i had to call back and get the rest of the hardware. the sent it out without to much hassle.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-30-2009, 09:08 PM   #18
texanidiot25
Eat My Rust
Their calipers were over priced when I was looking at it. You're better off getting some reman'd and loaded ones from a parts store for less.
Old 09-30-2009, 11:18 PM   #19
Frizzle Fry
No, for the 64. ...Tubby already has 2.5" spindles but can/will be going lower
Old 10-01-2009, 12:47 PM   #20
Rreemo
Rreemo's Avatar
Yeah, it's been a while....I suppose they must have been just regular drop spindles then.
If that's the case though, what was their reason for yours being the wrong size....perhaps they sent you 73+ spindles? Are they sending you the right ones now or just refunding you?
72' LWB Cheyenne
73' Camaro Z28/RS
70' Chevelle RagTop
00=ss=00
Old 10-01-2009, 05:30 PM   #21
Ackattack
Ackattack's Avatar
I don't really know what they're for for sure, just that they're wrong.
A new set should be on there way, and they're supposed to be sending me a ups tag or something to ship back the wrong ones.
Old 10-24-2009, 02:33 AM   #22
Ackattack
Ackattack's Avatar
Well after about 3 weeks of waiting since I tried to install my first set of modular spindles I finally got the new ones installed:
Couple of comments:
First, as advertised these moved the wheels inboard which has solved my clearance issues
When I was installing them, I put on the brake rotor, and the passenger side rotor was hitting the spindles when I tightened down the spindle nut. Nothing a little grinding didn't take care of. I figured I'd have the same thing on the drivers side, but to my surprise I didn't....oh well.
Like I said before CPP sent UPS out to pickup the incorrect spindles (at their expense). I told them to go ahead and order me a set of spindles and then refund me my money when they get the wrong ones back. I figured they'd try to refund me only the cost of the original spindles, not the shipping. To my surprise they did me right, and refunded the shipping too.
Some how I also ended up gettting the brackets for mounting the stock calipers. I didn't order these, as I was planning on making my own, but I guess I'll use them since I have them.
So overall I'm pretty happy. The spindles achieved what I wanted and CPP treated me fairly after they sent me the wrong parts.
Old 10-24-2009, 08:26 AM   #23
lolife99
67-72 parts collector,…
lolife99's Avatar
CPP seems like they are always having to correct their orders.
I wonder why they just can't get it right the first time?
I truely belive that CPP doesn't have one employee that owns/drives or has any knowledge of these trucks or their own products.
That's why I will continue to support ECE. These guys are truck guys.
Keith
Convert to disc brakes.
Old 10-24-2009, 11:00 AM   #24
leddzepp
Moderator
leddzepp's Avatar
I live locally to CPP. Their guys at the counter are VERY knowledgeable. Most people at the Brothers truck show use their stuff and have nothing but good things to say about them. I always read about mail order horror stories. That is not the case if you go there in person.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
