Old 01-11-2010, 12:44 PM   #1
Hart_Rod
Hart_Rod's Avatar
My side marker light fuel filler idea
I've been working off and on trying to figure out a cool, but fairly simple fuel filler modification for my under the bed gas tank. I've read a lot of threads on different ways to do this and have seen some really cool stuff that people have come up with, including in the bed, tail light and side marker light. While most the ones I have seen are very functional, most of them require modifications that involve cutting and welding on the bed. Since my truck is already painted and the bed has been linered, I gave myself some pretty tight parameters on what I wanted to create, such as:
1. It should be a fairly simple mod that most people could accomplish with minimal skill and tools.
2. It should be bolt on and use the existing holes.
3. Absolutely NO cutting, welding or drilling would be done on the bed.
4. It should not take away from the lines of the truck.
5. And lastly, it needed to be fairly cheap.
Well, here's what I came up with. I still have to do some fine tuning, but I'm very happy with how it's turning out. Once I go smooth with it, I'll probably do a write up on the install. What da ya think????
Parts:
Cabinet hinge (home depot part #H1068C-UC-C5)
Piece of 4" x 1 3/4" eighth inch steel (requires two 1" bends to form a "C")
super glue
side maker light
marine fuel filler cap - http://www.westmarine.com/ http://www.westmarine.com/whitecap--..._209_001_500**
Originally Posted by 0331grunt
I like the idea. More pics? Info? Keep the ideas coming!!
I'll post more once I get it fine tuned.
Originally Posted by oldblue1968chevy
do you have to do any kind of cutting to inside of bed.....willl gas pump fit in there even lol?
looks clean do a faq asap!
None, nope, nada, Zilch!! It fills up great.
Originally Posted by big_al_71
Rob, that looks like a hinge from a kitchen cabinet, Is it?
Probably so. I was walking down an aisle at Home Depot and picked it up.
Originally Posted by sgaylord
Nice set-up, I like the requirements and I'm definitely interested. I too have been thinking about something along these lines. I like all the mods I have seen (in bed, tail light, stake pocket, and marker light). I have been leaning towards the stake pocket or marker light. Some of the tail light mods I have seen look like they need more rigidity or the light could open going down the road. I can't do the bed floor because like yours my bed has a liner. How flimsy is the marker light when you open it to add gas? Are you using a cap that does not need to be removed to fill the tank? I think you would almost have to.
It's not flimsy at all. It has a very strong spring coupled with an "over-center" mechanism, which spring loads the open and closed positions. They way my setup is designed, you have to glue in the screw for the front hole, but on the rear hole you have the option of gluing it in OR you can put the screw into it's original keeper. Either way, it's not coming open. Screwing it in the orignal keeper will also prevent anyone from messing with it. As far as the filler neck and cap, I'm using the boat filler gas cap that has a spring loaded "handle". It's tight, but very easy to take off and on. I don't think they make a gas cap like you are talking about that will fit down in the hole (there's only a little over 2" to work with). I added a picture of the cap I'm using.
Hart_Rod is offline   Reply With Quote
Old 01-11-2010, 12:53 PM   #2
71swb4x4
71swb4x4's Avatar
Re: My side marker light fuel filler idea
Looks pretty cool. I can't wait for the full write-up.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-11-2010, 12:58 PM   #3
gcburdic
Restoration Virgin!
gcburdic's Avatar
Great Idea Rob.....subscribed!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 01-11-2010, 01:00 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Thumbs up Re: My side marker light fuel filler idea
Looks great Rob! Only problem is you can't get a filler hose in there if you live in a state where there are large rubber boots on the end. Otherwise, that's the way to go....minimal parts needed, no cutting required
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-11-2010, 10:56 PM   #5
Hart_Rod
Hart_Rod's Avatar
I still have some more pictures to take. I also want to do a video of the fill.
Thanks!
Do you have a picture of the gas nozzle you're talking about? Any measurements?
Old 01-11-2010, 11:00 PM   #6
big_al_71
big_al_71's Avatar
thats a great job Rob!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-11-2010, 11:12 PM   #7
POPO1984
POPO1984's Avatar
looks sweet
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 01-11-2010, 11:17 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
looks sweet! what did u do for a filler hose? gas tank to cap
John
1999 Toyota Tacoma 4x4
Old 01-11-2010, 11:22 PM   #9
Hart_Rod
Hart_Rod's Avatar
Thanks!
Originally Posted by POPO1984 View Post
looks sweet
Thanks!
I had an exhaust shop bend me a piece of 1 3/4" of pipe. I still need to weld a couple of tabs on to permanently mount it to the bed.
Old 01-11-2010, 11:29 PM   #10
Restrorob
The One And Only !!!
Restrorob's Avatar
Looks like a neat idea, I believe this is the nozzle he's talking about;
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 01-11-2010, 11:56 PM   #11
my67chevytruck
Under Construction
my67chevytruck's Avatar
I believe they are talking more along these lines, the pump has the boot, it recycles the fumes for better greenhouse effects, and if not depressed will not dispense fuel, of course you can manually depress the boot, and fill , but it may be a tight spot on the marker light ...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 01-12-2010, 02:57 AM   #12
leddzepp
Moderator
leddzepp's Avatar
That one is not a problem
This is closer to what I mean...there are some where the boot comes down even further than the one you have pictured. I did the marker mod on my truck, and it was next to impossible to get the filler in there. I ended up going with a Blazer neck, and relocating to the inside of the bed. Rob's technique and materials are perfect if you don't have to deal with a booted filler.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 01-12-2010, 03:42 AM   #13
Smallz72project
Smallz72project's Avatar
Great idea! Although from the litteral sense with just the bare mechanics of it...it is a bit of a pain in the neck. I have seen this mod done up close and personal and the angle is just super tight to get the nozzle in there with out mareing up the paint in some form or fashion. The ones I have seen completed used a modified gas door of of a S10. I wonder how well the cabinet hinge would work on the tail light? Might be able to get a better approach possibly.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 01-12-2010, 05:55 AM   #14
Larry S
Larry S's Avatar
Im watching this one. Looks good.
Larry S is offline   Reply With Quote
Old 01-12-2010, 09:12 AM   #15
Mudder
Mudder's Avatar
I have seen a plastic gas cap that has a hole just big enough for the nozzle and does not have to be taken off to be filled. The hole has a sping loaded closure that closes everything up tight when you remove the hose. Might work good in tight places.
Mudder is offline   Reply With Quote
Old 01-12-2010, 09:27 AM   #16
chevy72pu
chevy72pu's Avatar
Here is a picture of one from the Moultrie swap meet last November. Not very detailed picture though.
How 'Bout them Dawgs!
'10 Traverse LTZ
03 Silverado Z71 ext cab
99 Yamaha Grizzly 600
72 C10 350/350 sportside bed.
68 C30 flatbed. 350 4-speed.
"I've got a good memory, it's just short!"
chevy72pu is offline   Reply With Quote
Old 01-12-2010, 10:34 AM   #17
oldblue1968chevy
I like that!!!!
No specs on the bends by chance?
John
Old 01-12-2010, 10:43 AM   #18
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
I don't know about this one looks like it would scratch up the paint with time if you are not very very careful. Just like some door key holes that get scratched up with time after a while. Looks good though...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 01-12-2010, 01:18 PM   #19
Hart_Rod
Hart_Rod's Avatar
I think that one will still work.
It would be easy to check. Take your side light out the next time you fill up and see how difficult it is to get the nozzle in there. I've been filling mine this way for almost 3 months and haven't had one problem.
I haven't had any problems filling it, but maybe the FL nozzles are made differently. The same concept should work with the tail light without any problem. The only problem with going the taillight route, you have to cut some of the bed supports out in order to route a fuel filler hose. I will probably play with this concept on my Crewcab since it isn't painted yet.
Thanks.
I don't think they make a cap like that, that would be small enough to fit in the small area.
That one uses a door lid off of a later model truck. Same concept, but it doesn't use the original side marker holes.
I like that!!!!
Two 1" bends front each end to form a "C". You want to leave approximately 2" in the middle. The middle dimension should equal the depth of the tail light pocket. I initially used an "L" bracket, but decided to go with the "C" bracket to add more support to the mounting point.
Are you saying it would get scratched from the light or the fuel nozzle?
Old 01-14-2010, 11:26 PM   #20
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Nice work!
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 01-18-2010, 10:05 PM   #21
lytemup454
lytemup454's Avatar
I love it! I was wondering what you did about venting the system and it appears that the link doesn't work.
lytemup454 is offline   Reply With Quote
Old 01-19-2010, 02:23 AM   #22
Racinaround
Racinaround's Avatar
sub.
1950 Chevy 1500
1961 C-10
1969 C-10
1971 Chevelle
2008 Dodge HD3500 Tow Rig
Racinaround is offline   Reply With Quote
Old 01-19-2010, 11:42 AM   #23
HuggerCST
HuggerCST's Avatar
Looks great Rob!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 01-24-2010, 11:43 PM   #24
Strut
Strut's Avatar
Here guys this is what I did with mine:
1972 Chevy C10 SWB
1999 GMC Sonoma Mini
2008 Yamaha R1
2007 Harley Nightster
Strut is offline   Reply With Quote
Old 01-25-2010, 02:05 AM   #25
Sinisterspeed
Sinisterspeed's Avatar
I like this one, However in oregon your not allowed to fill your own vehicle so allowing some minimum wage bone head that will sooner or later ding the side of my truck I think I will take part of this idea and try to figure out how to make it go behind the tail light where there is less chance he/she will hit the quarter panel.
Nice work though!
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
