Old 12-19-2011, 10:47 AM   #126
ilovnos
ilovnos's Avatar
Re: 68 aka "Chained in Porterbuilt Prison"
Oh, I'm very interested in the hood. Would like pic when you get a chance. Thanks--Dave
68 Chevy SWB Stepside--under construction--now Fleetside w/18's & 20's--getting ready for 350 TPI motor w/700r4
67 Camaro--17x8's and 19x12's--C5 & Airride Technologies susp. (not finished)
09 Tahoe--lowered w/20's
Superformance Cobra--347 stroker w/Weber injection--polished 17's--SOLD
08 Scion Xb w/ground effects and 19's (son's car)
ilovnos is offline   Reply With Quote
Old 12-19-2011, 10:48 AM   #127
67cheby
67cheby
67cheby's Avatar
one other question , i notice the top of the fender to bedside area is open and then the bottoms of the inner bedpanel to bedsides are capped, just thinking out loud but if you are driving in the rain are the tires going to throw water up into the bedsides and then will it be trapped ? or is there drain holes we just can see ?
67cheby is offline   Reply With Quote
Old 12-19-2011, 11:29 AM   #128
jtp67-72
jtp67-72's Avatar
Originally Posted by n2billet View Post
I see how your tub bolts to the side of the bed (nutserts) but what are your plans for the very top?
Actually Keith it is very stout in that area especially when the flat flanges are installed reverse on the tubs where it bolts to wood. However since I have spent hours fitting the tub to the bed panel with no intentions of seam sealing the top side (tub to panel--just paint to paint) I may panel bond a couple of small bolts to the outer panel at the tub top to keep from having a rubbing effect-although when completely bolted down it will be unlikely--Make sense??
If it doesn't work like I think-I can always go back and cut that 4-5* angle into the tub at top and have it butt like stock tubs instead of flushing inside.........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 12-19-2011, 11:35 AM   #129
jtp67-72
jtp67-72's Avatar
That bottom capping is gaped at ends--but after tubs install-that open area will be seamed sealed -not much chance of water entrance...fender idea would be PIA --just thru that out there..........lol............jim
Old 12-19-2011, 11:56 AM   #130
67cheby
67cheby
67cheby's Avatar
LOL, that makes sense , i figured you had thought of the water issue just checking in case you hadnt .
Old 12-19-2011, 06:25 PM   #131
jtp67-72
jtp67-72's Avatar
I knew u had my back!!! Back on the dash this week--trying to get bedsides done to bolt back together cause wheels are do in 2 wks-trying to get backspacing perfect to narrow rearend-U can do all the figuring U want but nothing better than putting bed down over tires &wheels and measuring between-Can't mess up that way!!That's why all the work on inner panels-I'm anal about tire to wheel lip distance and also look how crisp the new wheel well lip is without the inner spot welded to it--Only going to do this once!! this is the wheel...........20 x 8 1/2 and 20 x12's
http://driverzinc.com/product/schott-mod5/
Old 12-19-2011, 06:30 PM   #132
67cheby
67cheby
67cheby's Avatar
nice !!
Old 12-19-2011, 10:18 PM   #133
jtp67-72
jtp67-72's Avatar
See if these give a better look at tub layout-Mike u can see where tubing stops above marker lite-no reason to extend further and it gives water relief!!
Also would allow me to do this gas filler trick if i wanted--probably not though-when finished the cap was to be body color and perfectly flat...........jim
Old 12-19-2011, 10:21 PM   #134
jtp67-72
jtp67-72's Avatar
pics of gas filler on last truck--PITA to do but slick............jim
Old 12-19-2011, 11:51 PM   #135
67cheby
67cheby
67cheby's Avatar
nice !
Old 12-20-2011, 12:08 AM   #136
shawno72
C/10 junkie
shawno72's Avatar
That is slick.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 12-20-2011, 02:00 AM   #137
VA72C10
VA72C10
VA72C10's Avatar
That's my #2 favorite gas filler mod besides huggercst's I believe rear light gas filler mod? But I was going to do like above because I wanted to run the LED taillights with the billet trim and they wouldn't work with the taillight filler mod.
Old 12-20-2011, 10:36 AM   #138
jtp67-72
jtp67-72's Avatar
Here's the link to it if U ever want to use ----But I found it somewhere else cheaper----------same part.............jim
http://www.bmschoppers.com/eshopprod...h_Mount_Po.htm
Old 12-20-2011, 11:51 AM   #139
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Figured id jump in on this build thread...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-20-2011, 03:01 PM   #140
VA72C10
VA72C10
VA72C10's Avatar
I actually found one on ebay a while back when I was planning this mod. Have the exhaust pipe for the bottom bend and the stake pocket...just never got around to finishing the project I intended it for.....some day!
Old 12-23-2011, 11:08 AM   #141
Hart_Rod
Hart_Rod's Avatar
This is what I used on my 68. You can get it at a boat shop for about $45.
Hart_Rod is offline   Reply With Quote
Old 12-23-2011, 06:21 PM   #142
jtp67-72
jtp67-72's Avatar
explain the design on the hinge-maybe I missed a thread---I like alot.....jim
Old 12-23-2011, 07:06 PM   #143
Hart_Rod
Hart_Rod's Avatar
I was referring to the pop up gas filler, but now that you asked, , here's a link to the side marker mod:
http://67-72chevytrucks.com/vboard/s...d.php?t=380571
Old 12-23-2011, 07:46 PM   #144
jtp67-72
jtp67-72's Avatar
Yeah I knew you were--I like the smooth one better for were I had it but the one u show is the trick especially in your pic--I'm always interested in new ways--wait till you see what i'm going to try on the license plate.......jim
Old 12-29-2011, 11:23 PM   #145
jtp67-72
jtp67-72's Avatar
A little update---still working on body panels with a bodyman buddy of mine who is having rough time financially --He is working panels before he has to give up his shop!! Nate sent me a late Christmas present with this rear cab panel kit (just layed in for now) Also got my front 14" grand sport rotors and dropped spindles from Boris (way2lo) Thanx guys!!
Hey Mike--(67 cheby) My wife says "your NOT going to cut that perfect fender (in epoxy) for those big ol' tubz are u"??? I said "with your permission" one of these days!!! LOL She just walked out of shop shaking her head!! She didn't see where I had cut this gaping hole in a perfect door for bearclaws in between body work!!.................Ya'll all have a good new year!!!................jim
Old 12-30-2011, 12:15 AM   #146
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Awesome work! Love the tail gate mod too! The fenders may be much, but once you did it and the truck was done, may be pretty awesome I think!
Ryan
1969 Chevy milk truck
Old 12-30-2011, 12:17 AM   #147
mooseknuckles
mooseknuckles's Avatar
awesome work man!
mooseknuckles is offline   Reply With Quote
Old 12-30-2011, 12:32 AM   #148
jtp67-72
jtp67-72's Avatar
Tell U how crazy I am--I have probably 6-8 extra fenders-been thinking about cutting my bodyman buddy loose on one and rough in body work just to see!! just bought a flawless pair of valve covers off ebay---I think once installed it would freak people...........we'll see..............jim
Old 12-30-2011, 12:39 AM   #149
Dieselwrencher
Nothing else, it'll be bad azz garage wall art!!!!!!!!!!!!!!!!!
Ryan
Old 12-30-2011, 12:39 AM   #150
VA72C10
VA72C10
VA72C10's Avatar
Looking really good!!! And some GREAT parts!!!
