Old 12-23-2012, 12:57 PM   #76
duallyjams
duallyjams's Avatar
Re: My brides new ride
Originally Posted by jb1016 View Post
Added a tach as well, nice work!
the tach is a repro
Originally Posted by Bomp View Post
Looks fantastic.
thanks I wish I had you welding skils
Originally Posted by Captainfab View Post
Looks great
Did you paint the bezel or is it just bead blasted?
It's painted , I went through three different colors of silver , still not sure if I like the color.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-23-2012, 11:30 PM   #77
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The new cluster looks great!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-24-2012, 03:22 AM   #78
hemifalcon
Hey.. where did you get that tool for the vent window rivets??
hemifalcon is offline   Reply With Quote
Old 12-24-2012, 10:12 AM   #79
duallyjams
duallyjams's Avatar
thanks
bought it from another board member it was kinda pricey not sure if I had to do it over again if I would buy one , look in the fact section Alan has a good write up on vent windows.
James
IG duallyjams
Old 12-24-2012, 11:31 AM   #80
62 Barnfind
62 Barnfind's Avatar
Originally Posted by duallyjams View Post
The vent windows there are a couple of threads on this one is in the fact section.
This is a 2 person job well it is easier with 2 people , again measure everything first and take pics.
I followed the direction in the write up that Allen did for pulling them apart. After getting everything apart and cleaned up ( I did not paint anything, wanted to keep the truck as is ) I out them together different then Allen did.
First I put the flat rubber in first using the rivet and tool that comes in the kitAttachment 976208
now I took out the bottom 2 rivet and pulled the frame up enough to get the other gasket in. I sprayed the back of the gasket with WD40 , you can feel it when it pops into place
Attachment 976209
I used the tool to put the bottom 2 rivet back and used it on the one vent window river.
Attachment 976210
I installed the vent window assembly back into the then I used window weld and put the glass in now i did it this way because when I pulled them apart i left the glass in , after replacing all the rubber with the old glass they worked great until I reinstalled the into the door then they would not close so I pulled the glass out installed them into the door then installed the glass and they work
Where did you buy the tool at? I will be doing vent windows soon.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-24-2012, 02:43 PM   #82
duallyjams
duallyjams's Avatar
mikes bump & grind but be for warn they are no longer a vendor on here do to a lot of bad deals
Originally Posted by theastronaut View Post
Everything looks great James!
Thanks , I start by reading through one of your threads to see how you did it.
James
IG duallyjams
Old 01-19-2013, 06:10 PM   #83
duallyjams
duallyjams's Avatar
Time to address the truck leaning to one side. The PO lowered the truck by heating the spring with a torch.
grinder , air chisel , little heat , rivets flying
cut the spring to get it out but you can still what happens when you heat it up
James
IG duallyjams
Old 01-19-2013, 06:18 PM   #84
duallyjams
duallyjams's Avatar
I bought everything from NoLimit ( board vender )3" drop spring , 2" lowering blocks , shock relocator and shocks , panhard bar
old verses new
This is some really nice stuff . The only problems that I had was me not paying attention. Thanks to Rob from taking time out of his busy day to answer my question and help me along. Went for a quick ride and it's a big difference in ride quality.
Here is a thread about NoLimit parts http://67-72chevytrucks.com/vboard/s...d.php?t=477839
James
IG duallyjams
Old 01-19-2013, 06:37 PM   #85
shawno72
C/10 junkie
shawno72's Avatar
Looking good man!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-19-2013, 06:45 PM   #86
Bomp
Bomp's Avatar
Lookin good Man!
Bomp is offline   Reply With Quote
Old 01-19-2013, 06:57 PM   #87
likaroc13
Rollin' Old Skool
looks nice! gotta ride better for sure
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-20-2013, 03:12 PM   #88
duallyjams
duallyjams's Avatar
Originally Posted by shawno72 View Post
Looking good man!!
thanks
Lookin good Man!
definitely worth it
James
IG duallyjams
Old 01-20-2013, 03:28 PM   #89
theastronaut
theastronaut's Avatar
That looks really good. I like the shock placement and angles.
theastronaut is offline   Reply With Quote
Old 01-22-2013, 03:44 PM   #90
duallyjams
duallyjams's Avatar
Went over to a buddy of mine shop , he made up some tail pipes for me.The truck is super quite now.
James
IG duallyjams
Old 01-22-2013, 05:14 PM   #91
62 short step
62 short step's Avatar
What mufflers you running?
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 01-22-2013, 05:36 PM   #92
duallyjams
duallyjams's Avatar
magnaflow / I can post a pic if you want
James
IG duallyjams
Old 01-22-2013, 06:15 PM   #93
62 short step
That's cool. Sounds good?
1965 c-10
86 chevy c/k 20
Old 01-23-2013, 12:24 PM   #94
duallyjams
duallyjams's Avatar
not the best pic
James
IG duallyjams
Old 01-27-2013, 05:07 PM   #95
duallyjams
duallyjams's Avatar
The rear kit from Rob ( Nolimit ) leveled out the truck. Can't say enough about how much I like his rear set up.
James
IG duallyjams
Old 01-27-2013, 05:11 PM   #96
duallyjams
duallyjams's Avatar
Today I gave in and replaced the steering box with one from http://www.redheadsteeringgears.com/ super fast delivery and a great product.This truck steers so easy with a manual box (even the wife has no trouble ) I didn't see the need to upgrade to power steering
James
IG duallyjams
Old 01-27-2013, 05:18 PM   #97
duallyjams
duallyjams's Avatar
Doing something with the bed wood soon will be on the to do list.
James
IG duallyjams
Old 01-27-2013, 06:48 PM   #98
HugoV
What did the new steering box run you?
HugoV is offline   Reply With Quote
Old 01-28-2013, 09:40 AM   #99
duallyjams
duallyjams's Avatar
call them for a quote
James
IG duallyjams
Old 02-21-2013, 01:03 AM   #100
66redw/white
made in america
66redw/white's Avatar
really diggin on this truck man. youve done all the perfect fixes.
2005 gmc sierra- 4/6, t56, cammed 5.3. 4.10, big bars, and brakes.
sounds good
1964 c10-283 powerpack, 3 on the tree
2004 corvette- lowered, borla, tuned. slow
my old girl
1966 c10- 305v8, t-5 sold
66redw/white is offline   Reply With Quote
