05-30-2013, 02:37 PM | #126 |
A day late and $1 short...
Re: Project "Shifted"
It better make a big difference with a price tag over $300! You have to pay to play right?!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
06-06-2013, 09:36 PM | #127 |
hey rob, just found this thread, truck is looking good! glad to see my old frame put to use!
06-07-2013, 09:09 AM | #128 | |||
Thanks!
Simple tool for a simple man, Quote:
Thanks Mike, I couldn't have done it witout you, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-15-2013, 07:19 AM | #129 |
I really like the Holley LS bracket setup! Here are some pictures of the completed bracket setup bolted on.
06-15-2013, 10:01 AM | #130 |
That does look nice !
Posted via Mobile Device |
06-15-2013, 07:51 PM | #131 |
Thats awesome!
-Rus |
06-23-2013, 11:14 AM | #132 |
Thanks!
Thanks! I finally got the motor cleaned up and re-installed. I also bolted up the accessory setup from my 68 just to make sure everything would fit correctly....it does...... Pics!
06-23-2013, 11:34 AM | #133 |
Hey I thought I was going to get to help with that!!
07-04-2013, 10:30 AM | #134 |
1 step forward and 2 steps back. Got the 2 piece driveshaft, but the motor mounts are to high, arrrggghhhh!!!!
07-04-2013, 11:17 AM | #135 |
Man of Mini-Talents
Well, crap! How does that happen?!?
How can you lower the motor mounts?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
07-04-2013, 11:24 AM | #136 |
I'm not sure, . I called Nate at PB and he is building me a set of shorter ones next week.
07-04-2013, 11:36 AM | #137 |
67-72 parts collector,…
Normally there is a 2" spacer required under the carrier bearing.
I see you have something under it,... but how much? Do you think your driveshaft tube diameter is too big? The first shorter shaft,... is usually just and extension of the trans tailshaft. (very close to the same angle)
07-04-2013, 11:47 AM | #138 | |
07-04-2013, 12:06 PM | #139 | |
'72 GMC Suburban 1/2 Ton (Red) '68 C10 Short Fleet (OG 503 Light Green and Patina) '70 C30 Dually (OG City of Charlotte Welding Truck) Past 67-72's Chevy Trucks '68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS) |
07-04-2013, 12:43 PM | #140 |
Rob that sucks you're having all this trouble!
-Rus |
07-05-2013, 01:18 PM | #141 |
Rob, could your trans x-member be mounted too high on the frame? It's hard to tell in the picture, but it looks like it is really high on the frame.
07-05-2013, 03:29 PM | #142 | |
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
07-05-2013, 04:18 PM | #143 |
Sucks about the driveshaft problem Rob, I'm interested in how you went about measuring for it. Did you go with the 3" for more horsepower potential.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
07-05-2013, 04:58 PM | #144 | ||||
Such is life, there are way worse problems out there than this, LOL. Quote:
On a better note, the 68 S/C truck is coming together nicely so far.....
07-05-2013, 05:15 PM | #145 |
Formerly- 1972SuperCheyenne
Both trucks are looking killer Rob.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
07-05-2013, 05:22 PM | #146 |
Rob I am in complete awe of that engine setup in the 68.
07-05-2013, 08:38 PM | #147 |
Rob here is my setup and your trans x-member is higher.
Posted via Mobile Device Posted via Mobile Device |
07-05-2013, 08:44 PM | #148 |
07-05-2013, 08:45 PM | #149 |
07-05-2013, 09:00 PM | #150 |
Floppydoodle does your trans crossmember sit flush with the bottom of the frame rail. I don't mean to hijack Robs build thread.
