Old 07-08-2014, 09:51 AM   #276
shearjs
shearjs's Avatar
Re: Project: Rufus Restoration
I thought for sure I'd have this thing back on the road by now. I've still been plugging away, it's just taken a little longer than expected. I got some new injectors in last week, and put the intake and fuel rails back on. Also spent some time getting the new engine harness connected and ready to go. I even managed to find the elusive a/c line fitting that is needed to connect the LS pressure sensor to the a/c line. With a little luck, this should be purring this weekend. On a side note, another project made it's way to the house over the weekend. I guess I'm going to need that bigger garage sooner than I thought.
shearjs is offline   Reply With Quote
Old 07-08-2014, 10:57 AM   #277
Rusbuilt
Rusbuilt's Avatar
Looks like you're very close!! What's the plans for the new truck?
Rusbuilt is offline   Reply With Quote
Old 07-08-2014, 11:05 AM   #278
shearjs
shearjs's Avatar
So close! For the near future, I'll probably just drive it and enjoy it. Long term, I'd like to do an independent front suspension and 4 link rear. With a straight axle in the front and leaf springs front/rear, it feels like riding in a covered wagon with a herd of ponies pulling you. Maybe do some sort of modern power train upgrade, similar to the GMC. It's unfortunate that PB isn't making a dropmember for this particular model yet. Maybe one day.
Old 07-08-2014, 01:09 PM   #279
Low Elco
You don't need it. I think that's one of 'em that the crown Vic conversion works on. Neet ol truck!
Low Elco is offline   Reply With Quote
Old 07-08-2014, 02:27 PM   #280
nlped
nlped's Avatar
Sure does! I am building my wife a '56 that belonged to her Grandfather. I got the complete front k-member/suspension from a Vic with a 4.6 modular motor. I'm going to be putting a Coyote 5.0 in it when it's all said and done.
Sweet project and cool ole F*RD
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 07-08-2014, 02:29 PM   #281
JRANGER
JRANGER's Avatar
man, thats a cool old truck...
JRANGER is offline   Reply With Quote
Old 07-14-2014, 09:27 AM   #282
shearjs
shearjs's Avatar
Made a little more progress this weekend. All wiring is done, aside from the cruise control. The a/c hoses are crimped and installed. I swapped out the internal transmission harness to take care of the leak at the pass through connector o-ring. Radiator back in. Tonight, I plan to install radiator hoses, fill with coolant, flash the pcm with the new tune, and bring this old girl back to life. Fingers crossed, no weird noises!
Old 07-14-2014, 10:27 AM   #283
Rusbuilt
Rusbuilt's Avatar
Good luck tonight bro! She's looking good!
Old 07-14-2014, 08:45 PM   #284
shearjs
shearjs's Avatar
Today is the day I've been anticipating the past 6 wks. Installed hoses and coolant, checked everything for leaks. Turn of the key, and she's alive!
Old 07-14-2014, 09:54 PM   #285
nlped
nlped's Avatar
Sounds wicked!
Carter
Old 07-15-2014, 12:10 AM   #286
swamp rat
swamp rat's Avatar
^^x2^^
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 07-15-2014, 01:17 AM   #287
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Great work turned out nice!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 07-15-2014, 08:36 AM   #288
mcbassin
Still Learning
mcbassin's Avatar
Sounds great Jason! !!
Congrats
Old 07-15-2014, 07:32 PM   #289
nlped
nlped's Avatar
Correct me if I'm wrong but this is a 5.3, right?
Carter
Old 07-15-2014, 09:10 PM   #290
shearjs
shearjs's Avatar
Originally Posted by nlped View Post
Sounds wicked!
Originally Posted by swamp rat View Post
^^x2^^
Congrats
Thanks guys! I'm pretty pumped to get it back on the road again. Ed, it's a 6.0 from an 04 Silverado 2500, LQ4 variation I do believe.
Old 07-25-2014, 05:27 PM   #291
shearjs
shearjs's Avatar
2 steps forward, 1 step back. I've had a couple setbacks that have kept me from being back on the road again. The tune has been tweaked a couple times, and is idling and running smoothly now. I'm having a tranny issue that's keeping the trans from shifting after replacing the internal wiring harness. I'll be investigating that more this wkend and will hopefully get that straightened out. Also having a bit of an issue getting the a/c tuning straightened out. The compressor will engage and blow cold by manually engaging it via VCM controls on Hptuners, but will not automatically engage via the a/c request wire. At this rate, I'm going to be needing more heat, and less a/c by the time it's cruising again.
Old 07-26-2014, 09:30 AM   #292
Hart_Rod
Hart_Rod's Avatar
Go to the AC section of your tune and make sure that the RPM that the ac is disabled is not zero'd out. Also, if you could post a picture of the a/c table that would really help.
Hart_Rod is offline   Reply With Quote
Old 07-26-2014, 09:39 PM   #293
shearjs
shearjs's Avatar
In my tune, the AC request type is set to analog cycling, and the rpms are set accordingly. From the brief research I've done, it seems different year pcm's process the ac request in different ways. 98-02 LS1's required a 12v+ for the request, while some others had a serial code. I'm still working with my tuner to figure out what setting the computer needs to recognize the request, or if maybe a segment swap, etc. needs to be done. If we get anything figured out I'll definitely let you know. What year is the engine and pcm from on your green truck? Also, I think I figured out the tranny issue I was having. Operator error. My plug needed to be rotated 180 degrees. The plastic cover on the plug just needed to be rotated to let the connector fit properly. I've switched the plug orientation, but haven't tested it yet. I'll know more tomorrow morning.
Old 07-27-2014, 11:51 AM   #294
shearjs
shearjs's Avatar
As ridiculous as the tranny screw up was, I'm happy to say she's shifting good now. At least one notch off the to do list.
Old 07-28-2014, 08:19 PM   #295
Rusbuilt
Rusbuilt's Avatar
Glad you're marking things off the list!
Old 07-28-2014, 10:32 PM   #296
Bennett68C10
Bennett68C10's Avatar
Truck sounds awesome Jason, really nice job on the motor work and AC install
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 08-01-2014, 04:39 PM   #297
shearjs
shearjs's Avatar
Thanks guys. I'm currently replacing the power steering pump and idler pulley, and blasting the bracket that holds the alternator and ps pump while it's off. It's been bugging me for a while, so it'll be good to make it look new again. I couldn't seem to ever get all the air purged out of my ps/hydroboost system, so with the cheap price of the pump, I went ahead and replaced it. Let's hope this takes care of the problem. Once the brakes are full power, I'll probably go ahead and schedule a dyno appointment to get this dude dialed in and back on the road.
Old 08-04-2014, 11:35 AM   #298
shearjs
shearjs's Avatar
Man it's getting crowded in here. Rufus' older sister almost hit her head going through the door. We're going to have to do something about that soon.
Dyno appointment scheduled for next week!!! Finally get this old heap back on the road.
Old 08-04-2014, 08:33 PM   #299
Rusbuilt
Rusbuilt's Avatar
Like!!
Old 08-10-2014, 08:17 PM   #300
shearjs
shearjs's Avatar
It's go time!
