#226 |
![]() Join Date: Apr 2005
Re: 55 TF Stretched Cab/Fleetside/LSx/Trailblazer Frame
Kewl build
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#227 |
A320 Pilot/USAF Retired
Looking forward to hearing her run!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#228 |
just checking out your online pics. you know the hood is supposed to go over the ENGINE, not the ROOF, right? ha ha
looks good. are accy drive relocator brackets a necessity or more a personal preference thing? nice job anyway. can't wait to see the body come together. mine is still waiting. |
#229 | ||||
Thanks Kim. I really hope to hear it run this weekend. Quote:
Has a date for Clemdaddy’s get together been set? Thanks for stopping by. I love your surburban. I hope I have the video/AUDIO proof this weekend! Quote:
As to your question about the brackets, my initial mock up looks like the "truck" pulley system would be too tight to use the Camaro duel fans. I really like that setup because it cools the GTO without ever a problem. Once I get the cab welded and installed, I will revisit the pulley system. If i can make the truck brackets fit, I will use them and give the "corvette" stuff back to the 58 Corvette project.
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod Last edited by ricott; 01-20-2015 at 02:50 PM. |
#230 |
I hear ya. I will be interested to see what brackets you end up with. I am doing the envoy frame as well, so interested yo see how it all turns out. hopefully feb will have some time for the project.
keep up the great work and, of course, the great documentation pics. we ALL love that stuff. dennis |
#231 |
just curious, when it comes time for body welding, what are you using? mig? tig? oxy acetylene? I will be using mig but have heard that sometimes the welds can show especially on a hot day. different expansion contraction ratios from weld material to sheet metal donor materials.
#232 | |
I really hope I can go back to the "factory" brackets on the Driver's side of the engine, although I will probably be using the aftermarket Passenger side AC bracket on this build.
Rick's 55 TF/Fleetside/LSx build 1958 Corvette LS1/T56 Build 1966 GTO LQ9/T56 Restomod |
#233 |
isn't it funny how that works. we want a tool but we make do with something less and the project gets done. then, when we are older and won't use the better tool as much-we buy one. it doesn't get used as much, if at all, but it looks good in the shop and we dream of what we would do with it. sometimes when we do use the new tool it is for somebody else. you gotta laugh.
#234 |
Well last Thursday I spent almost six hours reworking the tranny mount. Because I'm using the T56 tranny, I needed to raise the perch area almost 3 inches. I mocked it up using my digital angle finder (on top of the tranny in the first picture). I used the center section of a second trailblazer mount to make the raised part. When the mount was finished and the tranny mounted, the Tranny angle was 2 tenths of a degree off (down) over the rear end angle. I could adjust it (raise the tranny mount using a shim), but it is close enough for government work!
![]() ![]() ![]() I spent a couple of hours Saturday installing the clutch and gas tank, and mocking up the gas line. I'm planning to work late Thursday afternoon/evening - so I'm sure it will run then. As always, more to come. Ricky Time spent Thursday/Saturday: 8 hours Total time: 168
#235 |
Looks good.
Kim |
#236 |
Well done! What is your target angle with respect to level?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#237 |
The angle was 3.5 degrees at the pinion. I zeroed the angle finder to my garage floor, the placed the angle finder on the pinion yoke - it was 3.5 degrees. I then placed the angle finder on the tranny and adjusted until I got the 3.5.
#238 |
IT'S ALIVE!!
I left work early and went and pulled two fuseblocks. Got home and hooked one of them up, then powered up the fuel pump and fixed a couple of drips. ![]() ![]() I hooked up my four wires, then hit the starter wire relay and it fired right up. I only ran it a little because I don't have any coolant in the engine. Click on the picture below to hear it run. I LOVE THESE ENGINES!! I'm headed to Dallas this weekend for work so it may be a couple of weeks before the cab welding begins. As always, more to come. Ricky Time today 3 hours Total time: 171
#239 |
That sounds great.
Congrats. Kim |
#240 |
![]() Join Date: Jul 2012
Sounds really good! Way to go Ricky.
#241 |
Those that have followed this build from the beginning may recall that I said my primary focus in 2014 would be my wife's 1958 Corvette. Well, it wasn't. I got going on this truck and really put her (and her project) off – it has always been the "next" one. While in Dallas last week an acquaintance of ours that has been working (on and off) on his car project for a number of years was diagnosed with cancer and will not live to finish it. That really hit home, and I have vowed to get our 1958 Corvette (that we have owned since January 1985) in a running and driving condition in time for my wife to drive it around the block by her birthday in late August.
Here is the truck reassembled ready for welding to begin. I will put its cover on and let it sleep through this year. ![]() ![]() Wish me luck - here are a couple of pictures of the Corvette frame. The first goal is to make this a roller. If anyone would like to follow along on the Corvette, click on the Corvette link in my signature. ![]() ![]() And one of the car. ![]() Thanks again everyone for your comments – and I look forward to getting back on this truck late this year - and possibly meeting some of you on the Power Tour this summer.. Ricky
#242 |
Following the Corvette. Make that lady happy.
#243 |
Great prioritization, love the Corvette and I will tag along too Ricky.
#244 |
Looks like you have a great start on a very nice Vette for the better half there. It takes a very special woman to put up with us gear heads that spend way too much time out in the garage with our build projects. I am sure she will love the Vette. Take care.
#245 |
Good karma, your heart is in the right place. Well Done
Been there, wrecked that ![]() |
#246 |
Nice Vette.
Hope you make your goal. Kim |
#247 |
I'll be following the Vette project!
#248 |
"Happy Wife, Happy Life"!!!
I'll be watching the Vette build!
#249 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU |
#250 |
Ricky: What's the latest on Vette (or truck)? dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
