Old 03-04-2013, 10:53 AM   #26
67_ShortFleet
67_ShortFleet's Avatar
Re: trimming lower control arms
Why is the part that I outlined in red left and not removed?
Matt
Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784
My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924
My philosophy on tires is the same as cigarettes. "smoke them if you got them"
HAPPILY DIVORCED!
67_ShortFleet is offline   Reply With Quote
Old 03-04-2013, 12:00 PM   #27
SCOTI
SCOTI's Avatar
The material left behind doesn't prohibit any function so it's just an asthetic deal. Remove it if it bothers you. If it doesn't, no reason to do the extra work.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-10-2013, 04:18 PM   #28
lolife99
67-72 parts collector,…
lolife99's Avatar
Bringing this thread to the top for a board member,...
Keith
Convert to disc brakes.
Old 07-29-2014, 08:25 PM   #29
lolife99
lolife99's Avatar
Bringing this thread to the top for a board member.
Keith
Old 09-30-2014, 03:43 PM   #30
crakarjax
crakarjax's Avatar
Are those spot welds, and if drilled out would the whole assembly just pop off? I'm thinking that might be easier than cutting through the whole thing.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 04-02-2015, 09:13 AM   #31
Hart_Rod
Hart_Rod's Avatar
Did you try this?
Hart_Rod is offline   Reply With Quote
Old 07-18-2015, 11:51 PM   #32
crakarjax
crakarjax's Avatar
Originally Posted by Hart_Rod View Post
Did you try this?
No, haven't yet but I'm getting close to the point where I might.
One question though, what about the bump stop? It seems like you'd still want a bump-stop to limit the control arm travel. Otherwise some components would mash together that shouldn't, right?
Old 07-19-2015, 03:36 PM   #33
crakarjax
crakarjax's Avatar
Did some searching here and it seems that the answer is that if you cut the bump stops out, you run the risk of scrubbing your tires on the inner fender. Cutting them down does give you more travel but the amount of acceptable travel depends on:
- Your wheel and tire size
- Do you still have inner fenders
- How low can you drop assuming airbag failure (if you are bagging it) and still drive
Also I came across posts in which people verified that you can just drill the spot welds with 1/2" bit and then chisel the whole thing off.
Old 08-09-2015, 02:11 PM   #34
crakarjax
crakarjax's Avatar
Ok so I did drill through the spot welds with a 1/2" bit and then just beat the bracket off entirely with a BFG. Took all of 5 minutes!
Old 08-06-2018, 12:46 PM   #35
BIGglaSS
BIGglaSS's Avatar
Sorry to bring up an old thread...
I'm about to install Belltech 3" drop spindles. Stock 15x6 wheels.
I noticed in this thread that the bump stops are cut off. Following this article in HR Mag, they left the bump stops.
https://www.hotrod.com/articles/low-...ody-chevy-c10/
I installed Moog 6454 with one coil cut off. It brought the front down 1.5", and it looks like there is still adequate bump stop clearance.
For the guys that cut off the bumpstops, did you put anything else there, or leave them off? I'm thinking about trimming it off, then mounting a bolt-on bump stop.
This is on a squarebody...
BIGglaSS is offline   Reply With Quote
