Old 05-30-2013, 02:37 PM   #126
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: Project "Shifted"
Great job on the brake lines.
I finally got access to a set of good benders.
I consider these the best.
And it really makes a difference when bending lines.
They are Swagelok brand,.. like these.
It better make a big difference with a price tag over $300! You have to pay to play right?!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 06-06-2013, 09:36 PM   #127
mike14_07
mike14_07's Avatar
hey rob, just found this thread, truck is looking good! glad to see my old frame put to use!
mike14_07 is offline   Reply With Quote
Old 06-07-2013, 09:09 AM   #128
Hart_Rod
Hart_Rod's Avatar
Originally Posted by c10Dream'n View Post
just awesome, keep up the good work..
Thanks!
Originally Posted by jasonhall View Post
Cool tool
Simple tool for a simple man,
Those are sweet, but to complicated for me, .
Originally Posted by 72BlckButy View Post
Looks good Rob!
Keith... is that an internet picture or some bends you've produced recently?
Thanks!
Thanks Mike, I couldn't have done it witout you, .
Hart_Rod is offline   Reply With Quote
Old 06-15-2013, 07:19 AM   #129
Hart_Rod
Hart_Rod's Avatar
I really like the Holley LS bracket setup! Here are some pictures of the completed bracket setup bolted on.
Old 06-15-2013, 10:01 AM   #130
jasonhall
jasonhall's Avatar
That does look nice !
jasonhall is offline   Reply With Quote
Old 06-15-2013, 07:51 PM   #131
Rusbuilt
Rusbuilt's Avatar
Thats awesome!
Rusbuilt is offline   Reply With Quote
Old 06-23-2013, 11:14 AM   #132
Hart_Rod
Hart_Rod's Avatar
Thanks!
Originally Posted by Rusbuilt View Post
Thats awesome!
Thanks!
I finally got the motor cleaned up and re-installed. I also bolted up the accessory setup from my 68 just to make sure everything would fit correctly....it does...... Pics!
Old 06-23-2013, 11:34 AM   #133
C10_ustacould
Hey I thought I was going to get to help with that!!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-04-2013, 10:30 AM   #134
Hart_Rod
Hart_Rod's Avatar
1 step forward and 2 steps back. Got the 2 piece driveshaft, but the motor mounts are to high, arrrggghhhh!!!!
Old 07-04-2013, 11:17 AM   #135
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Well, crap! How does that happen?!?
How can you lower the motor mounts?
Zoomin is offline   Reply With Quote
Old 07-04-2013, 11:24 AM   #136
Hart_Rod
Hart_Rod's Avatar
I'm not sure, . I called Nate at PB and he is building me a set of shorter ones next week.
Old 07-04-2013, 11:36 AM   #137
lolife99
67-72 parts collector,…
lolife99's Avatar
Normally there is a 2" spacer required under the carrier bearing.
I see you have something under it,... but how much?
Do you think your driveshaft tube diameter is too big?
The first shorter shaft,... is usually just and extension of the trans tailshaft.
(very close to the same angle)
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 07-04-2013, 11:47 AM   #138
Hart_Rod
Hart_Rod's Avatar
Keith - I had the carrier bearing raised about 2.5" and it was still a no go. I talked to Nate and he said the motor was to high... As far as the diameter of the drive shaft, I've asked for pics and advice on doing this for about 3 months but have got very little info, so I went with what I knew. I didn't even think to ask the guy at the driveline shop about the diameter because I hadn't heard it was an issue..... You would think that as many of these extreme setups that are out there, that there would be a write up of the do's and don'ts of measuring and building the driveline for them.......
Old 07-04-2013, 12:06 PM   #139
CLTBurban
CLTBurban's Avatar
Agreed! I've searched all over the forums and really couldn't find much other than multiple members running into the vibration issues... with no real known solution.
'72 GMC Suburban 1/2 Ton (Red)
'68 C10 Short Fleet (OG 503 Light Green and Patina)
'70 C30 Dually (OG City of Charlotte Welding Truck)
Past 67-72's Chevy Trucks
'68 C10 Short Fleet on 20" Coy's, '72 C20 Suburban (Ochre Big Block), '69 C20 Suburban (Silver), '69 C10 Suburban (Red/White on Boyd's), '72 C10 Short Fleet (Ochre on Torq's), '70 C10 Short Fleet (POS)
CLTBurban is offline   Reply With Quote
Old 07-04-2013, 12:43 PM   #140
Rusbuilt
Rusbuilt's Avatar
Rob that sucks you're having all this trouble!
Old 07-05-2013, 01:18 PM   #141
jlaird
jlaird's Avatar
Rob, could your trans x-member be mounted too high on the frame? It's hard to tell in the picture, but it looks like it is really high on the frame.
jlaird is offline   Reply With Quote
Old 07-05-2013, 03:29 PM   #142
RRC
RRC's Avatar
Looks that way to me too....I haven't figured out my driveshaft yet but right now I no my trans x member is lower. I also thought about lowering the engine mounts as well . Time will tell. If Nate thinks engine mounts then I would go that way because you will be able to lower the trans mount to.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712
Instagram: http://instagram.com/rockylakekustoms
Rocky Lake Kustoms
Russ
RRC is offline   Reply With Quote
Old 07-05-2013, 04:18 PM   #143
Bennett68C10
Bennett68C10's Avatar
Sucks about the driveshaft problem Rob, I'm interested in how you went about measuring for it. Did you go with the 3" for more horsepower potential.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 07-05-2013, 04:58 PM   #144
Hart_Rod
Hart_Rod's Avatar
Driveline angles are very complicated. as I'm sure everyone knows. I just wish there was more information or a how to on this subject. I researched and asked questions before I finally bit they bullet and ordered the shaft. I know Nate will help me figure it out an I plan on doing a thread dedicated to this subject once I'm done.
Such is life, there are way worse problems out there than this, LOL.
You are correct, the transmission mount is to high. But that is were is supposed to be based on a max of 5 degree output shaft angle. The problem with lowering just the transmission mount without also lowering the motor, is the angle that it places the tranny output shaft. It currently is set a 5 degrees (probably the max you want). If I lower the the tranny mount to get the drive shafts at the proper angle, it create an 8-9 degree angle on the transmission output shaft. So the only way to fix that is to lower the motor mounts. Clear as mud?!
Originally Posted by Bennett--G4L View Post
Sucks about the drives haft problem Rob, I'm interested in how you went about measuring for it. Did you go with the 3" for more horsepower potential.
Honestly, I never really thought about the diameter of the drive shaft. I took it to the drive line shop and explained to him what I was doing and told him the motor/tranny combo that it was going to be connected to and this is what he built. I did a lot of research and asked a lot of questions but the diameter of the shaft was never mention as an issue. If the diameter were smaller, it would allow me to raise the carrier bearing up more, but as it sits, I already have it raised up 2.5-3 inches. I'm not sure I would want to any higher even if I could.
On a better note, the 68 S/C truck is coming together nicely so far.....
Old 07-05-2013, 05:15 PM   #145
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Both trucks are looking killer Rob.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 07-05-2013, 05:22 PM   #146
Bennett68C10
Rob I am in complete awe of that engine setup in the 68.
Keith
66 Suburban
IG: bennett68c10
Old 07-05-2013, 08:38 PM   #147
floppydoodle
floppydoodle's Avatar
Rob here is my setup and your trans x-member is higher.
floppydoodle is offline   Reply With Quote
Old 07-05-2013, 08:44 PM   #148
floppydoodle
Old 07-05-2013, 08:45 PM   #149
floppydoodle
Old 07-05-2013, 09:00 PM   #150
Bennett68C10
Floppydoodle does your trans crossmember sit flush with the bottom of the frame rail. I don't mean to hijack Robs build thread.
Keith
66 Suburban
IG: bennett68c10
