ecu placement ideas?
I'm going to be putting my ecu on the drivers side fender well, anyone got any idea's on how to do so? something clean or/and unique?
i have a ammo can I've been pondering the idea with, it has foam in it and is water tight...just a thought and ponder at this point
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
![]() Join Date: Sep 2008
Re: ecu placement ideas?
Here is mine
72 Blazer 69 Stepper (sold) 72 Burb |
meowMEOWmeowMEOW
You'll have to page through my build since I can't find the photobucket image, but if you look through it or my "LSx powered 66 C10" video on my channel, you can see how its setup.
I have my ecu behind the drivers headlight, with all the wiring and relays out in the open on the inner fenderwell. Easy-access everything.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Apr 2010
I used an old sign to mount the pcm and tac module to the drivers fender. You just have to be careful of the hood hinge and spring when closing the hood.
I used the s-10 mount and just put it right behind the headlight under the horn and horn relay. Mine's a '66 so the inner fenderwell has some angular flats that are good for bolting stuff too.
Here's mine was kinda tricky. Had to remove the head light for the install to get the angle of the ecu just right or it would run into the head light and the fender well. I was only able to see the angle by looking through the side marker hole.
That's pretty close to the cover I got on mine too
mine is inside the center console...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
I was looking at where to put mine last weekend. I settled on the drivers side behind the head light. should turn out pretty accessible and hide most of the wiring. it also works with stock harnesses.
_______________________________________________ A project can be finished, but a car is never done. 1967 chevy K10 step ![]() 2002 chevy Impala Latest Project http://67-72chevytrucks.com/vboard/s...d.php?t=605308 |
#10 | |
I placed mine behind the gauge bezel.
![]() Join Date: Apr 2005
Firewall...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#13 |
![]() Join Date: May 2013
Rob, how tight is it under the battery? Do you have a auxiliary tray or something else?
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
#14 |
It's an Aux tray. Same amount or room as under the factory tray. I mounted the water pump for the supercharger heat exchanger under the tray.
#15 |
Rob can you explain how the oil catch can is plumbed. By the way that is sweeeeeet.
#16 |
From intake tube (between throttle body and MAF) to passenger side valve cover. From drivers side valve cover to the catch can. From catch can to throttle body.
#17 |
![]() Join Date: Sep 2005
I used an 03 s10 zr2 computer mount just crewed to the fendor check out my build thread for pictures
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#18 |
Thanks thinking of adding one to my conversion, no blower on mine but have read that the ls are prone to sucking oil.
#19 | |
meowMEOWmeowMEOW
For the truck engines, there were reports of excess oil being found in intakes, but it wasn't a glaring mechanical problem. The main causes were dirty/failed pcv systems allowing blowby, and the use of overly-thin oil. People in cold climates would take the old school mindset of "thick in summer, thin in winter" and use something thinner than a 5w-30...this problem was even worse in vehicles using certain types of synthetic oil. A 5w20 synthetic IS thinner than its dinosaur-counterpart. Brands like Royal Purple and certain other racing oils have even been considered thinner. Some in the ls world think that Royal Purple and LS motors don't mix (at least without going to a higher base weight, like a 10w30). Personally, I have used the factory recommended weight of 5w30 in various brands including Royal Purple with no problems or changes in pressure. Also, and this is a BIG also....almost all modern close-tolerance engines will have oil consumption. All of the Chysler family engines from the same generation have problems as bad or worse in that sense. 6.1's had oil usage problems, the SRT4 with its turbo damn near required an oil catch as not to foul out the IAT. As modern engines are designed to run hot, tight, and with a little lubrication as possible...oils thin down, and as a result they are easily blown by. With no uncertainty I can say that a catch can is a valid mod to about 95% of cars on the market today.
#20 |
Thanks for the info B City. My ls is truck and 06 does this fall in the "early" category.
#21 |
Boosted Member
Put mine on the trans hump...will get covered with the center console.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#22 |
mines in the glove compartment.!
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
#23 |
hidden behind the dash....
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#24 |
#25 | |
my PCV "valve" is more like a restrictor, there's no spring/weight in there like on all the sbc's bbc's and bbo's i've messed with. I had a pretty good amount of oil in my intake when I pulled it to switch the knock sensors |
