Old 01-01-2014, 07:11 PM   #1
69cunningham
69cunningham's Avatar
Lss3
The time has come for the restoration of my 69 short stepside. Here’s a picture of it in 1981 with a fresh paint job.
I bought it in 1977 to drive to high school. It originally had a 307 with 3 on the tree, but by ’80 they had been replaced by an SS Chevelle 350 backed up with a Corvette 4 speed.
In 1982, the truck was disassembled for a complete restoration. The time and money wasn’t available so it sat in storage for the next 32 years.
I’ve collected a few parts for it over the years. The most important is the LS3 out of a 2010 Camaro. It was pulled out with 4 miles on it for an LS7 swap.
(Don’t ask about the Jeep in the in the background.)
Some of the parts being reunited after a very long separation. The engine is mounted using 911 GEN III conversion mounts from Early Classic.
The stock mounting location leaves more gap between the firewall than I would like. I slid it back 2 inches and will eventually drill new mounting holes.
The transmission is a T56 Magnum from American Powertrain.
69cunningham is online now   Reply With Quote
Old 01-21-2014, 10:13 PM   #2
69cunningham
Re: Lss3
Transmission Mount Progress:
The crossmember is made from 1X2 1/8" wall tubing. Braces are included to stiffen the frame so the cab won't flex out the top.
Purchased a stock type rubber transmission mount for a 1972 Camaro from Napa auto parts, 620-1024. This mount was used in many GM vehicles up into the 80’s.
Old 01-21-2014, 10:16 PM   #3
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Lss3
Sweet project and power plant..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 01-21-2014, 10:22 PM   #4
trkfrk
trkfrk's Avatar
Re: Lss3
I am tuned in for this build. Nice score on the motor and transmission.
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-21-2014, 10:22 PM   #5
69cunningham
Re: LSS3
Fuel Tank Work:
The tank is a Boyd Welding Special EFI A1000 aluminum fuel tank. I had Boyd not include provisions for the fuel level sender or fuel pump.
I am customized it to hold an in tank fuel pump from a 2012 Silverado fuel pump, MU1949. The pump was shortened to fit the tank.
I made a fuel pump clamping ring. It will need to be welded to the tank.
Old 01-22-2014, 01:55 AM   #6
uxdesigner
Re: Lss3
Amazing start, can't wait to see more. Any info (part #) for the fuel ring/o-ring?
uxdesigner is offline   Reply With Quote
Old 01-22-2014, 11:16 AM   #7
69cunningham
Re: Lss3
The O-ring came with the 2012 Silverado fuel pump. RockAuto lists it as an AC Delco G41 (22682111).
Old 01-22-2014, 12:16 PM   #8
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Awesome project. I'm in. Love the powerplant and tank.
Old 01-22-2014, 01:24 PM   #9
mikeleeshields
mikeleeshields's Avatar
Re: Lss3
Very good start.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 01-22-2014, 01:47 PM   #10
Low Elco
Re: Lss3
Innnnnteressssting..... I'm in. Nice motor!
Low Elco is offline   Reply With Quote
Old 01-22-2014, 01:50 PM   #11
faribran
Re: Lss3
will you have to use a high hump to clear this tranny?
faribran is offline   Reply With Quote
Old 01-22-2014, 01:53 PM   #12
69cunningham
Re: Lss3
I am currently looking for a high hump. It doesn't look like it there is enough clearance, but I haven't put the cab on since I got the trans.
Old 01-22-2014, 05:33 PM   #13
faribran
Re: Lss3
very good. thank you. that is what i was guessing..... i like your project so far... keep it up... maybe the weather will get warmer soon.
Old 01-25-2014, 05:10 PM   #14
69cunningham
Re: Lss3
I just tried setting the cab on the frame to see the clearance to the transmission. I definitely need a high hump transmission cover. It might work if I were willing to slide the engine forward and tip the back of the trans down, I would rather have the drivetrain where I have it.
Anyone have a good high hump?
Old 01-25-2014, 05:37 PM   #15
trkfrk
trkfrk's Avatar
Re: Lss3
I installed the same transmission and used a high hump. It fits very well. I did have to notch the cab floor to clear the top of my transmission because I moved my engine back a couple of inches. Keep the pictures coming your build is looking good.
Mark
Old 01-28-2014, 09:43 PM   #16
69cunningham
Re: Lss3
I got the fuel pump clamping ring welded in. I’ll try to fit the tank to the frame this weekend so I can get the tank powder coated.
Old 02-04-2014, 06:16 PM   #17
Rusbuilt
Rusbuilt's Avatar
Re: Lss3
Very nice!
Rusbuilt is offline   Reply With Quote
Old 02-04-2014, 07:27 PM   #18
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Lss3
Looks like a cool project. I like your trans crossmember.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-04-2014, 08:52 PM   #19
mcbassin
Still Learning
mcbassin's Avatar
Re: Lss3
Nice welding on the tank.
Old 02-04-2014, 10:37 PM   #20
Hardesty454
Hardesty454's Avatar
Re: Lss3
Nice stuff going on here. Cant wait to watch some building! Wish I could find an LS3.
Where is Windor? Unless you meant Windsor over by Santa Rosa?
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 02-05-2014, 12:47 AM   #21
69cunningham
Re: Lss3
Oops! No one said that I could spell. It's Windsor, near Santa Rosa.
Old 02-08-2014, 03:49 PM   #22
69cunningham
Re: LSS3
Mounting the fuel tank:
When it comes time for final assembly on the truck, the fuel tank area is going to be very congested with the tank, hitch, bumper and bed all competing for the same area. To allow the tank to be installed without access to the top of the mounting bolts, I made bolt plates. They drop in to the top through existing holes in the frame. Rubber pads and nylocks will be added later.
I will need to notch to top of the frame to make room for the fuel filler hose.
Old 02-18-2014, 02:17 AM   #23
conman585
conman585's Avatar
Re: Lss3
Updates?? It's been a long 9 days...
conman585 is offline   Reply With Quote
Old 02-18-2014, 01:39 PM   #24
Hart_Rod
Hart_Rod's Avatar
Re: Lss3
Nice project. You're going to love the LS3.
Hart_Rod is offline   Reply With Quote
Old 02-18-2014, 01:55 PM   #25
steelhorse
steelhorse's Avatar
Re: Lss3
Looks like a cool build.
steelhorse is offline   Reply With Quote
