11-01-2018, 01:38 PM
#8
Originally Posted by Bowtie468
Another modification that i wanted was the addition of a 3rd brake light to the back of the cab. After looking at various units, i finally settled on the 16" Hot Slot from Watson's Streetworks. Because of the size of the light, the inner panel had to be cut out to get it mounted in place. It's pretty unnoticeable when it's off, but when you hit the brakes, it's impossible not to notice it ! In the last picture, you can see the acrylic lens protruding past the surface of the sheet metal. This lens was blocked down to match the contour of the cab panel, but not so much as to make it flush with the panel. It actually needs to wind up flush with the basecoat, which wasnt on yet. And let me stress that they dont sand too easily ! This was a bit tricky as you dont want to pile on basecoat to make it flush. A little more work than i thought, but the end result was well worth it !!
What grit did you block it down with?
