Old 02-14-2016, 12:35 AM   #401
junour11
Re: "Old Olive" 1970 C10 porterbuilt build
your truck looks sick bud.
junour11 is offline   Reply With Quote
Old 02-14-2016, 12:36 AM   #402
69short
69short's Avatar
That's awesome man. How'd it feel to drive it again?
69short is offline   Reply With Quote
Old 02-14-2016, 01:06 AM   #403
BLUIDVL
BLUIDVL's Avatar
Wicked build & good looking truck! Love the white frame.
BLUIDVL is offline   Reply With Quote
Old 02-15-2016, 05:59 PM   #404
mooseknuckles
mooseknuckles's Avatar
that thing is awesome.
mooseknuckles is offline   Reply With Quote
Old 02-15-2016, 07:22 PM   #405
randomco
Thanks guys! It was good to drive the truck again, but it needs a good tune and I am having some issues with the truck dying immediately when I try to put the truck in R or D. It idles perfectly in P or N, but as soon as I try to put it in gear, it dies. Any ideas? Just a tuning issue?
Josh
Josh
1970 Chevy C10 SWB build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=639787
1976 Chevy k10 Silverado Bought new in '75 by my Grandfather
1965 Lincoln Continental Convertible - SOLD
1965 Lincoln Continental Sedan - SOLD
randomco is offline   Reply With Quote
Old 02-15-2016, 08:12 PM   #406
Advanced Design
Advanced Design's Avatar
Other than a tuning or too low idle, is there a vacuum leak?
Advanced Design is offline   Reply With Quote
Old 02-15-2016, 08:15 PM   #407
randomco
I have a drive by cable setup so I tried dialing up the idle. didn't help. I'm almost sure I don't have any vscuum leaks but I'll definitely check
Josh
Old 02-16-2016, 11:48 AM   #408
aggie91
I'm just glad to be here!
aggie91's Avatar
Years ago, I had a truck that would do the same thing. It turned out to be the converter was to tight and would load up the engine enough to kill it.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-16-2016, 02:47 PM   #409
Advanced Design
Had the same thought...converter applied. Maybe lift the rear tires off the ground, support safely and try putting in gear.
Old 02-16-2016, 07:09 PM   #410
GoaterAz
GoaterAz's Avatar
Originally Posted by randomco View Post
Kept tbe smooth firewall look
The truck is coming out great man!
I had a question for you about this picture, I too have the Porterbuilt firewall filler panels welded in and I just got my Vintage Air kit. Did you fabricate a custom bracket for the evaporator where it meets the inside of the firewall? I don't see any mounting hardware on the engine side of your firewall.
Any advice on using the VA filler panel as template and drilling the 4 holes in the firewall is greatly appreciated.
You remember when drinking too many beers was a bad idea?
Me neither.
GoaterAz is offline   Reply With Quote
Old 02-16-2016, 11:40 PM   #411
randomco
Yes I just took the 1/4" bolts that came with the vintage air kit and welded the heads to the inside of the cab firewall where they tell you to drill the holes. Then slid on the evap and used the nuts in the inside. I taped the porterbuilt firewall panel with masking tape and held the vintage air firewall panel over the porterbuilt firewall and marked it out the holes with a sharpie. I think I used a .75" and 1.5" hole saw for the heater holes and ac holes, respectively.
Josh
Old 02-16-2016, 11:41 PM   #412
randomco
I was afraid of it being the TC. I'm going to get the truck tuned first and go from there.
Josh
Old 02-18-2016, 12:49 PM   #413
junour11
there is a chance you have a bad idle air control solenoid, it may not be adjusting for the load put on by the transmission. it is a quick fix.
Old 02-18-2016, 03:06 PM   #414
9teen69
9teen69's Avatar
Looks kickass, congrats on getting it on the road!...
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline   Reply With Quote
Old 02-18-2016, 04:09 PM   #415
bmfm64
bmfm64's Avatar
Nice work.
bmfm64 is offline   Reply With Quote
Old 03-04-2016, 02:01 AM   #416
randomco
Welp, swapped the lockup solenoid and pwm in the trans and the engine stalling issue is still there. I'm pretty sure it's the torque converter itself now. Getting a new one and hopefully that'll do it. Gonna be fun dropping the trans on this truck...lol
Josh
Old 03-04-2016, 09:37 AM   #417
Hart_Rod
Hart_Rod's Avatar
What do you have the idle set at? I'm sure with your cam it should probably be 850-900 rpm. Can you email me a copy of the tune?
Hart_Rod is offline   Reply With Quote
Old 03-04-2016, 09:39 AM   #418
coopdog
coopdog's Avatar
that thing is pure gangster
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 03-04-2016, 10:29 AM   #419
randomco
I had a professional tuner work with it for hours and could not overcome the load put on the motor when put in gear. We tried all sorts of options for increasing the idle and park and then drive and everything. There's definitely a trans issue.
Josh
Old 03-04-2016, 10:53 AM   #420
Hart_Rod
Hart_Rod's Avatar
Gotcha. What torque converter do you have in it?
Old 03-04-2016, 10:59 AM   #421
randomco
It's a 2200 stall that came with the trans. Not sure the brand. It looks like a precision but I was told it was not. The trans company is sending me a new TC.
Old 03-04-2016, 11:07 AM   #422
randomco
You can see it here
Josh
Old 03-04-2016, 11:12 AM   #423
Hart_Rod
Hart_Rod's Avatar
With more stall?
Old 03-04-2016, 11:19 AM   #424
randomco
With more stall?
no the same converter, they wanted $500 more in difference to get a larger stall 2500-2800 so I said screw it, just send me the free replacement for now. If I am not happy with it, ill buy another one later. I just want to be able to drive the truck now.
Josh
Old 03-04-2016, 11:24 AM   #425
Hart_Rod
Hart_Rod's Avatar
I would try to flip that converter and just get a 2800-3K one. Or you're gonna be swapping it again. Not telling you what to do, but just one of my lesson's learned.....
