Old 10-10-2014, 02:07 PM   #426
LS1Impala
Re: LS swappers, post up your pics!!
1968 C10 5.3/4L60E LS6 cam and a 3600 stall
1968 Camaro 6.0/4L65E T76 turbo 9"
1960 Impala LS1/4L60E all stock cruiser
LS1Impala is offline   Reply With Quote
Old 10-10-2014, 10:53 PM   #427
Sac
Nice truck. Take it you like LS swaps judging from your signature.
Green Survivor Father/Son Truck
<SeveredTies>
Sac is offline   Reply With Quote
Old 10-11-2014, 12:17 AM   #428
LS1Impala
Haha yeah I do...the Impala and Camaro have been on the hotrod power tour the last few years with minimal mechanical issues and great gas mileage. They run good and make great power!
Old 10-15-2014, 12:41 AM   #429
Gobuffalo
Gobuffalo's Avatar
Out with the old and in with the new!
LQ4/4L80E going in a 70 Suburban 4x4.
This has been an on going project for almost 3 years. It was really hard to cut off the brand new stainless exhaust to get this done. I liked all the horsepower of the big block. I hated the 6 mpg.
Gobuffalo is offline   Reply With Quote
Old 10-15-2014, 11:35 AM   #430
HemiChallenger71
HemiChallenger71's Avatar
Originally Posted by texasld View Post
5.3 from 2001 Suburban. 4l60e too. Just set it in this weekend.
Attachment 1304845
I have to know what valve covers those are? They look great.
HemiChallenger71 is offline   Reply With Quote
Old 10-15-2014, 02:27 PM   #431
texasld
texasld's Avatar
Thanks man.
They are the Proform LS valve covers. They have several colors. You also have to get some type of coil relocation bracket. I'm not a huge fan of the ones they sell. (Made to bolt to the intake side of the covers). I purchased some off of eBay that I'm going to hide somewhere in the frame rail. Check the last page of my build thread for the link and picture for the brackets I have. Make sure you are getting brackets for the truck coil packs if you are running a 4.8 or 5.3.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 10-16-2014, 12:52 PM   #432
Rat72
Rat72's Avatar
Shoved my LS2 back about 6 inches. It makes the weight distribution nice and makes room for the front axle to tuck up so I can keep the truck as low as possible. I'm getting 8 inches of compression and another 8 inches of droop with this setup.
Rat72 is offline   Reply With Quote
Old 10-16-2014, 06:39 PM   #433
tinydb84
tinydb84's Avatar
Rat72 do you have anymore pics??
David
Instagram: myfabguy
Old 10-17-2014, 02:01 PM   #434
Rat72
Rat72's Avatar
Some more pics at Pirate, http://www.pirate4x4.com/forum/chevy...chevy-4x4.html
Old 10-18-2014, 12:14 PM   #435
Iceburgh
Iceburgh's Avatar
work in progress
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 11-04-2014, 11:07 PM   #436
gottattooz
gottattooz's Avatar
I stripped a 2004 GMC Savana 2500. 4.8l with a 4l85E, the entire wiring harness, fule pump, steering column and dash cluster swapped into my 68 shortbed fleetside.
-Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline   Reply With Quote
Old 11-05-2014, 03:00 AM   #437
Gobuffalo
Gobuffalo's Avatar
Got some time in on this swap. Thought I'd share.
It works out that if you cut the middle out of the factory 4x4 crossmember an LS drops right in. In fact, 1 bolt hole in the stock motor mount lines up with 1 of the LS motor mount bolt holes.
Old 11-05-2014, 03:11 AM   #438
Gobuffalo
Gobuffalo's Avatar
Doug Thorley headers fit great and don't hang below the frame. The only thing they hit was on the left side. At the farthest out side point it hit the edge of where the TC inspection cover bolts. I cut about 1/4" "knob" off that doesn't affect anything, and it fit.
Old 11-23-2014, 02:31 AM   #439
Gobuffalo
Gobuffalo's Avatar
Had to make the lower crossmember. I used 1" x .120 DOM and the outer pieces of the original crossmember. Fits great and clears the trans cooler lines.
Old 11-23-2014, 02:33 AM   #440
Gobuffalo
Gobuffalo's Avatar
Powder coated and installed.
Old 11-25-2014, 10:44 AM   #441
texasld
texasld's Avatar
That's pretty awesome!
1999 Jeep TJ
Old 12-08-2014, 07:57 AM   #442
Mjminino
Is there someone that could guide me in a direction/website with a how to, step by step to start doing this? I shouldn't have read this thread LOLOLOL!!! I have no idea where to start. Like if I go to the junkyard and snag a motor what all should I be grabbing for wires my current project is a 1964 C10. I'd like to snag an engine so I have some stuff to work on during the winter! ANY and ALL help is/will be greatly appreciated. Thanks in advance!
Mjminino is offline   Reply With Quote
Old 12-08-2014, 11:49 AM   #443
Indian113
Indian113's Avatar
You might want to use the open LS forum to get your answers to your questions. Everything you will need to know can be answered by the guy's on there. They walked me through my 5.3 in my S10.
Indian113 is offline   Reply With Quote
Old 12-15-2014, 10:13 AM   #444
mister twister
mister twister's Avatar
Lots of awesome trucks and info on here! Thought i'd post up a few pix of my 62..
5.3/700r made outta real tornadoes
mister twister is offline   Reply With Quote
Old 12-15-2014, 10:55 AM   #445
Hart_Rod
Hart_Rod's Avatar
For all of the 67-72 LS swap guys that don't have the time or tools to fabricate a DBW pedal mounting bracket, check this out:
http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Hart_Rod is offline   Reply With Quote
Old 12-21-2014, 09:14 PM   #446
68Stepbed
68Stepbed's Avatar
How did you hook up the TV cable for the trans?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 12-23-2014, 02:59 AM   #447
mister twister
I went to the junkyard and hacksawed the tv lever arm off of a carburetor from a truck or car cant remeber that had a 700r. I also cut off the bracket that holds the cable and welded it to the bottom of the 5.3 throttle bracket. Before I cut anything at the junkyard I measured the radius and the angle for the TV lever and matched the dimensions before i welded it to the 5.3 throttle body. Probably not the most ideal setup out there but it works.
Old 01-06-2015, 11:00 PM   #448
gixxer711
Originally Posted by mac72 View Post
Nice work guys they really look sweet
Heres a few of mine
Anyone know what accessory setup this is?
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 01-06-2015, 11:21 PM   #449
mooseknuckles
mooseknuckles's Avatar
looks like vintage air...
mooseknuckles is offline   Reply With Quote
Old 01-07-2015, 07:22 AM   #450
Mjminino
Man that looks b...e...a...utiful! I bet there is some money there! Totally worth it though.
