Old 04-14-2014, 10:43 PM   #726
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Project Lemon Drop: anything but stock!
Originally Posted by Joe Pass View Post
Seeing your pictures makes me think your TCC (700r) cable isn't set up to the proper throw causing some unnecessary slip. That might be the cause of excess clutch debris in he pan but its not unusual to have some because the initial break in (wear in) will create some excess.
Your pump could be a High volume with it designed to supply more fuel but not pressure unlike a high pressure pump which will deliver 12psi. If you have a high pressure pump with out a regulator it will not let the needle/seat seal and flood the engine which is your symptoms.
I will send you my contact info...Joe
Thanks, sounds like I need to get a tow up to you.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 04-15-2014, 05:34 PM   #727
Joe Pass
Joe Pass's Avatar
Give me a call when you have a chance, tonight about 7-730 I'll be in my shop if you want to chat...If you need to have it looked at,we can arrainge something but I would think we could narrow these issues down before you decide to tow it.
Joe Pass is offline   Reply With Quote
Old 04-15-2014, 11:35 PM   #728
jugernot
Life, Be In It.....
jugernot's Avatar
Sorry, I lost track of the time with work stuff. I'll try tomorrow.
Old 04-25-2014, 08:18 PM   #729
jugernot
Life, Be In It.....
jugernot's Avatar
Update. I met a member today (Joe Pass) who came by to help dial in the engine and get rid of some of the gremlins haunting the engine. We added a fuel pressure regulator which required changing the fuel line to the carburetor. Adjusted the timing (which was way over 12 degrees), Adjusted air/fuel mixture on the carburetor and put the vacuum line on the correct side of the carburetor. We discovered that a much needed bracket for the 700r4 transmission cable was missing from the carburetor, which was causing slippage in the transmission. I ordered the part from Summit and will put it on when it arrives.
After all that the engine is running smooth and sounds so much better. We went for a short drive to the gas station to fill up the empty gas tank. We drove through some puddles, while it was raining. A first for Joe in a hot rod and a first for Lemondrop.
If all is good after putting on the transmission bracket, I’ll take a trip up to Joe’s shop for some fine tuning (more so to check out Joe’s shop). He is a wealth of knowledge and I’m happy with what he did. He understands how supped up engines can be temperamental.
THANKS AGAIN FOR YOUR HELP JOE. Great to meet you.
Old 04-25-2014, 09:08 PM   #730
Joe Pass
Joe Pass's Avatar
Thank you for the kind words, its amazing the amount of work you have into "Lemon Drop" and I'm glad to participate. I look forward to you coming up for a visit...Joe
Old 04-25-2014, 09:13 PM   #731
Hart_Rod
Hart_Rod's Avatar
MAJOR PROPS TO JOE!!!!!
Hart_Rod is offline   Reply With Quote
Old 05-18-2014, 10:49 PM   #732
jugernot
Life, Be In It.....
jugernot's Avatar
I had Lemondrop towed up to Joe’s Place. What an awesome shop. We did some more researched and learned that the trans TV cable was not properly installed, parts were missing which has a great effect on how the transmission operated. I ordered a new TV cable, linkage and bracket which is highly recommended by Bowtie Overdrives. After installing the proper parts and performing the recommended tests to document the transmission pressures, we took Lemondrop for drive. Wow what a difference.
We also replaced the fuel pump with a 6 psi rating, which eliminated the need for the fuel regulator. We rebuilt the carb and Joe made a few more adjustments to dial in the tuning.
During the week it was at Joe’s place he looked over the truck and found some things that I had installed incorrectly, rag joint, shocks and suspension components and some things that broke and needed repairs, speedo gear and leaking seal. He shimmed the transmission to get a better angle on the drive shaft. He replaced the leaking steering gear box with a remanufactured one and made an adaptor for the power steering hoses. He installed the proper parking brake cable bracket on the hand brake under the dash. He made a stainless steal line for the vacuum line and PVC line. Joe also did something that I didn’t expect, but was happy that he did, He checked the AC system for leaks and then charged the AC with a 1.5 lbs of 134. On a hot day the AC temp at the vent was 53 degrees.
A friend of Joe’s dialed in the alignment and wheel bearing preload.
Friday I went back to Joe’s and we went for a drive. Words cannot describe the why I was feeling. Happy, excited and yet nervous that the engine was gonna start running rough and we’d be stuck on the side of the road. We took Old Redwood Hwy north and drove to Healdsburg. We drove through town and received a “thumbs up” and “nice truck” from a few people we passed. From there we jumped on Hwy 101 back to Joe’s. Everything worked great. RPMs at approximately 70 mph were at 1800.
Today I drove Lemondrop home, which was the longest trip to date that truck has taken. I am confident that I can know take it on some road trips and if I finish the truck up by next summer (still have interior and bed wood to doo) I’ll take it to some car shows.
Joe is a great guy with a lot of knowledge, which he is more then happy to share. I have to thank him for getting Lemondrop to this point as well as thank him for reigniting my interest in the truck. I can once again see the light at the end of the tunnel and its not too far away.
THANKS JOE.
Old 05-18-2014, 11:28 PM   #733
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Great to hear you are getting to enjoy your truck! Makes all the hard work and investment worth it. It is great to hear hoe Joe stepped up to help you get your truck's issues sorted out. WAY TO GO JOE!! I look forward to seeing some pictures of the truck out about town. Enjoy!!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 05-19-2014, 10:38 AM   #734
aggie91
I'm just glad to be here!
aggie91's Avatar
Awsome!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-19-2014, 12:22 PM   #735
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
This is a great news about Lemondrop! Glad to hear a positve update
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-19-2014, 12:27 PM   #736
lolife99
67-72 parts collector,…
lolife99's Avatar
Beautiful truck.
I've been following this build since the beginning.
Congrats on getting to this point.
Keith
Convert to disc brakes.
Old 05-19-2014, 03:30 PM   #737
67ChevyRedneck
67ChevyRedneck's Avatar
Kevin painted this truck in April 2007 and it still looks amazing! Still love the color.
So glad to hear she's on the road!
I painted my truck myself in 2006 and it looks like crap now
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-19-2014, 08:29 PM   #738
jlaird
jlaird's Avatar
Always nice to see board members helping each other out. Lemondrop looks CLEAN! Very nice looking truck.
jlaird is offline   Reply With Quote
Old 06-08-2014, 10:50 PM   #739
jugernot
Life, Be In It.....
jugernot's Avatar
I managed through the heat today and did a little work on my door panels. I cut the shape of the arm rest out of wood to a two dimensional shape of them. Then I used floral foam, which I cut and shaved until I was happy with how it looked. Next I carved in pockets for the door pull and the door latch. I still have to do a lot of fine tuning to do, including mocking up the power window switches, making holes for the bolts that attach the arm rest to the door panel and then once I’m happy with it I’ll fiberglass it and then repeat the process for the other door. All it all I'm happy with how it turned out.
Old 06-20-2014, 10:08 PM   #740
Joe Pass
Joe Pass's Avatar
I just checked in and see you have been busy....I'm leaning towards the vise-grip door openers myself...more traditional
Old 06-20-2014, 10:48 PM   #741
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
that is too funny.
Can't wait to see some progress on Lemon Drop!
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-22-2014, 03:22 AM   #742
Rokcrln
Rokcrln's Avatar
Looking good!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-28-2014, 07:35 AM   #743
Orangetonicclicc
Orangetonicclicc's Avatar
Did you use a vintage AC unit? And if so, did you go thru the firewall or underneath? I tried to find that page? Can you help me out I kind of want to go underneath!
Orangetonicclicc is offline   Reply With Quote
Old 06-28-2014, 11:37 AM   #744
jugernot
Life, Be In It.....
jugernot's Avatar
Hope this is what you are looking for.
http://67-72chevytrucks.com/vboard/s...&postcount=461
http://67-72chevytrucks.com/vboard/s...&postcount=407
http://67-72chevytrucks.com/vboard/s...&postcount=231
Old 06-28-2014, 03:03 PM   #745
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Good to see your still plugging away..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-11-2014, 10:54 PM   #746
chevytruckluver
updates...we need updates
Trey
72 Short Step
Old 09-11-2014, 11:44 PM   #747
Joe Pass
Joe Pass's Avatar
I agree.....Maybe he traded it in on a Suburu
Old 09-12-2014, 12:15 AM   #748
jugernot
Life, Be In It.....
jugernot's Avatar
Everyday I open the garage I see how nice the truck looks with its cover on. I'm happy that the cover is there to care for the paint. Then I see the pile of parts I have sitting on the counter that are just waiting to be put on the truck and remembers Joe's open invitation to come up "when ever" to put the parts on the truck. But then I turn around and see the unfinished front yard and remember that winter is coming. So in order to avoid having a fishing pond in the front yard, all of my attention lately has been to finish the yard before the rain comes. Yes I'm giving positive thoughts that we will get rain this year.
So I'm sorry to disappoint everyone. It has been hard not being able to get somethings done, even more so because I can see the finish line for the build.
Joe,
We will have to compare calendars and see what is available in Mid October. Thanks for checking in.
Old 09-12-2014, 08:37 AM   #749
Joe Pass
Joe Pass's Avatar
I look forward for a visit....a lot has happened since we talked last.
Old 10-26-2014, 01:55 PM   #750
jugernot
Life, Be In It.....
jugernot's Avatar
Okay, for those who have been patiently waiting and for those who got tired of waiting, I have an update. Not a big one but it is an update.
I have gotten caught up on the things around the house that needed my attention. So yesterday I had some time to work on the other inner door handle. I previously carved one inner door handle from foam and yesterday I made the other one.
After I got it all carved up and closely matching the other one. I figured out a way to fasten the leading edge of it to the door panel. Then I located a place on the door handles to put the electric window switches.
All of these appeared to work and fit into the project, but we'll see how it actually turns out. Once I get it all fine tuned, I'll cover it with fiberglass, sand and fit on the door panel. Thanks for checking it. Stay Tuned, more to come SOON……….Hopefully.
