#176 |
![]() Join Date: Apr 2005
Re: Project "Shifted"
I have an inch between mine.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#177 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Different oil pan?
#178 |
Mines off of a Fbody, 2002 Camaro Z28.
#179 |
Mine is a truck pan......but I have a f body pan that I'm painting and will be using
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
#180 |
I think you will have the same gap as I currently do when you swap to the Fbody pan. What tranny are you running? I'm using a 4L60E. Right now I'm setting everything back up the way I had it when I first did my measurements, and rechecking everything.
#181 |
I'm using a 700r4 trans.....that sounds like a good plan , hope it all works out.
#182 |
Thanks! When are you swapping your pan out? I got the new motor trusses and will try to get them installed this weekend.
#183 |
![]() Join Date: May 2013
Read the thread the other day and guess I got caught up on pictures and forgot to post
![]() ![]() Posted via Mobile Device |
#184 |
Truck and auto performance nut
not sure how I missed this one....sweet project...any updates?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#185 |
New transmission mount and drive line is done. Might be putting this up for sale.
#186 |
Looks good! I hope you don't sell it!
-Rus |
#187 |
Lord only knows what you have in store.
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#188 |
Wish I was closer. I would love to have this project!
#189 |
Why do you wanna sell it?
#190 |
![]() Join Date: Dec 2006
Wait, what are you selling? The drivetrain or the entire project?
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#191 | |
Still Learning
#192 |
I think it may be the entire project.
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=614365 68 & I'll Owe You 1 ![]() |
#193 | ||
Just a short road trip,
![]() Just thinking about moving on to something that is a little more "new driver" friendly Not 100% sure yet. Chevy sonic...... ![]() Quote:
![]() ![]() Quote:
Here's a list of most of the parts for the truck. I'm sure there are some more smaller things that I'm missing. Original rust free Cab (clear title) and front clip with all glass NOS Stainless vent shades bolt in high hump tranny cover New rubber cab mounts Factory Buddy bucket front seats with center console Original steel front and rear painted sport bumpers and brackets Hills fiberglass front tubs for dropped trucks 10 Gallon air tank with custom pin striping Custom gas pedal setup OEM inner wheel tubs Factory short bed chassis with front and rear Porterbuilt extreme dropmembers Porterbuilt tubular upper and lower A-arms Porterbuilt rear tubular trailing arms and crossmember Porterbuilt front radiator cross bar Porterbuilt transmission mount (with HartRod mods, ![]() Front and rear airbags, fittings and shocks New power rack and pinion with steering joints and rod 1.25" Adco sway bar CPP 2” dropped modular spindles with aluminum hubs CPP front and rear big brake kit (13”/12”)with powdercoated calipers (black), zinc coated rotors, and braided stainless brake lines New 20x10 and 20x8 Coys with BFGoodrich tires Custom 2 piece 3.5” driveshaft/slip joint 12 bolt rear with Eaton posi 3.73 gear and new ECE 5 lug axles Brake lines and braided hoses The chassis and all components have been painted with POR 15 2002 Z28 LS1/4L60E with only 25K documented miles MAF/O2 sensors Custom stainless cold air intake setup Holley accessory bracket spacer kit 2010+ Camaro manifolds with 2 new stainless Magnaflows Custom aluminum fuel tank with in tank fuel pump and sending unit (with braided fuel lines and Corvette fuel pressure regulator) Custom ECM mount LOKAR shifter linkage
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-24-2015 at 07:59 AM. |
#194 | |
Still Learning
![]() I totally understand. I have two kids myself. It was tough handing over the keys to both of them. BTW, they both drive chevy trucks...just saying. |
#195 |
this is the second time this has happened to me, I read an entire thread that I hadn't seen and when I get to the end, the truck is getting sold...... bummer. I say keep it, but I also know the thoughts that go through your head when you hand the keys over to someone.....
great build |
#196 | ||
It hasn't sold yet, so we'll keep working on it until it does or it's done, ![]() High hump is mounted, and the cab is back on.......looks like a truck now instead of a bunch of part, ![]()
#197 |
So" you post your sons truck up for sale for motivation? Lol jk Good to see y'all are getting some work done. It's looking good!
#198 |
Cab looks great on there
#199 |
![]() Join Date: Apr 2010
Do you have a fleet side bed for it or will you sell it with the stepside bed?
Wade |
#200 |
So cool Rob!
-Rus |
