Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-23-2016, 10:02 PM   #1
Heliarcn
72 Plaid Sub
Well, after several years of searching through the forums for invaluable information, I figured it's time to give back. I'm starting this build thread for my 1972 Suburban that I bought back in January. The plan is to restore the interior back to the original look with the correct highlander plaid and repaint the suburban in the original dark blue and white two tone. It's gonna run full Porterbuilt suspension and lay flat on the ground. Looking at LS3 or maybe a newer GM gen v motor. Here we go.
Instagram - 72_plaid_sub
Bret
1972 Chevy Suburban
1976 Blazer
Heliarcn is offline   Reply With Quote
Old 06-23-2016, 10:04 PM   #2
Heliarcn
Re: 72 Plaid Sub
Started the tear down a couple weeks ago.
Bret
1972 Chevy Suburban
1976 Blazer
Old 06-23-2016, 10:08 PM   #3
Heliarcn
Re: 72 Plaid Sub
More tear down.
Bret
1972 Chevy Suburban
1976 Blazer
Old 06-23-2016, 10:16 PM   #4
Heliarcn
Re: 72 Plaid Sub
Got the old motor and trans out.
Bret
1972 Chevy Suburban
1976 Blazer
Old 06-24-2016, 09:58 AM   #5
Hart_Rod
Hart_Rod's Avatar
Re: 72 Plaid Sub
Nice burb!
Hart_Rod is offline   Reply With Quote
Old 06-24-2016, 12:29 PM   #6
Heliarcn
Re: 72 Plaid Sub
Originally Posted by Hart_Rod View Post
Nice burb!
Thanks Rob. Heres a shot of the frame out before the rivet party.
Bret
1972 Chevy Suburban
1976 Blazer
Old 06-28-2016, 11:57 AM   #7
Heliarcn
Re: 72 Plaid Sub
Making room for the new Porterbuilt stuff.
Bret
1972 Chevy Suburban
1976 Blazer
Old 06-28-2016, 12:06 PM   #8
Heliarcn
Re: 72 Plaid Sub
I cut an X in the top of the rivets with a cut off wheel and then drilled them with a 3/8" bit. I kept the bit sprayed with Aero Kroil and only used 2 bits to remove almost every rivet in the frame. This is not a bad way to go if you don't like using an air hammer/chisel.
Bret
1972 Chevy Suburban
1976 Blazer
Old 08-16-2016, 01:43 AM   #9
Heliarcn
Re: 72 Plaid Sub
More progress. Full Porterbuilt roller a couple weeks ago.
Bret
1972 Chevy Suburban
1976 Blazer
Old 08-16-2016, 01:52 AM   #10
Heliarcn
Re: 72 Plaid Sub
Was originally going the LS engine route, but now I'm going to try an fit a 2015 Chevy L83 in the suburban. Hope I don't regret that decision.
Bret
1972 Chevy Suburban
1976 Blazer
Old 08-16-2016, 01:56 AM   #11
Heliarcn
Re: 72 Plaid Sub
Current situation. Modified the Porterbuilt LS mounts and got the L83 installed. Now I got to figure out the steering rack.
Bret
1972 Chevy Suburban
1976 Blazer
Old 08-16-2016, 03:57 AM   #12
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: 72 Plaid Sub
http://gmauthority.com/blog/gm/gm-engines/l83/
Type: 5.3L V8
Displacement (cu in / cc): 325 / 5328
Bore & stroke (in / mm): 3.78 x 3.62 / 96 x 92
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: overhead valve, two valves per cylinder, variable valve timing
Ignition system: coil near plug, platinum-tipped spark plugs, low-resistance spark plug wires
Fuel delivery: direct fuel injection with Active Fuel Management
Compression ratio: 11.0:1
Horsepower (hp / kW @ rpm): 355 / 250 @ 5600 (gas – SAE certified)
380 / 283 @ 5600 (E85 – SAE certified)
Torque (lb-ft / Nm @ rpm): 383 / 519 @ 4100 (gas – SAE certified)
416 / 564 @ 4100 (E85 – SAE certified)
http://www.trucktrend.com/how-to/eng...arger-install/
Rich
1972 K5 Blazer CST Click HERE
Old 08-16-2016, 08:33 AM   #13
nastety92
Re: 72 Plaid Sub
Really nice build. I would love to do something like this one day. Would you care to share how much $$ you dropped with Porterbuilt?
nastety92 is offline   Reply With Quote
Old 08-16-2016, 10:31 AM   #14
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: 72 Plaid Sub
Nice build.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 08-16-2016, 10:35 AM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 72 Plaid Sub
subscribing to this one,...
Keith
Convert to disc brakes.
Old 08-16-2016, 01:29 PM   #16
bL.A.zer90045
Re: 72 Plaid Sub
That's usually how *it*starts
bL.A.zer90045 is offline   Reply With Quote
Old 08-16-2016, 01:36 PM   #17
Heliarcn
Re: 72 Plaid Sub
I didn't buy everything from PB directly, but I dropped about $6K with them. Picked up the narrowed PB arms from a board member here and saved about $400 off PBs price. Picked up the shocks and bags online and saved about $100.
Bret
1972 Chevy Suburban
1976 Blazer
Old 08-16-2016, 03:13 PM   #18
tommys72
tommys72's Avatar
Re: 72 Plaid Sub
I'll follow along...need lots of pics though, cause i cant read good...so they tell me
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 10-26-2016, 02:29 AM   #19
LsJuan
Re: 72 Plaid Sub
LS swaps are bomb but are becoming a thing of the past. I will give you props for dealing with the new 5 gen
LsJuan is offline   Reply With Quote
Old 12-04-2016, 07:10 PM   #20
Red3+3
Re: 72 Plaid Sub
NICE!
Just saw this... Subscribed!
I'm in the process of getting an L83 out of a 2014 Tahoe myself. Planning on getting it installed on my old 1982 Silverado Stepside (Has a 6.2l Diesel in it right now!).
Keep up the good work!
Red3+3 is offline   Reply With Quote
Old 06-25-2017, 11:28 AM   #21
goldenburb
goldenburb's Avatar
Re: 72 Plaid Sub
Thanks for service tommys72...
Saw your burb on Instagram. .....😱 😱.
70 c10 2wd crashed Suburban
67 c10 2wd sb truck
67 c10 4wd lb truck
goldenburb is offline   Reply With Quote
Old 07-16-2017, 12:50 AM   #22
Heliarcn
Re: 72 Plaid Sub
Yeah, I've kept up the Instagram account a lot better than the forum. I'm getting back into it now. Should have some updates soon.
Bret
1972 Chevy Suburban
1976 Blazer
Old 11-22-2017, 02:17 PM   #23
Heliarcn
Re: 72 Plaid Sub
Well, I've done a lot of work since my last post, just haven't had time to update here. Will try to do some more updates of the build soon.
Lots of pics and updates on my Instagram @72_plaid_sub
Bret
1972 Chevy Suburban
1976 Blazer
Old 11-22-2017, 02:52 PM   #24
Heliarcn
Re: 72 Plaid Sub
Starting this back up from last August when I last posted pics of the build.
Mounting the Gen V L83 and 6L80E trans to check the fit.
Bret
1972 Chevy Suburban
1976 Blazer
Old 11-22-2017, 03:05 PM   #25
Heliarcn
Re: 72 Plaid Sub
Installing the Hill's Rod & Custom front inner fender wells. Delmo at Delmo's Speed hooked me up with these extreme drop inner fenders to tuck a 22" wheel and tire combo.
Bret
1972 Chevy Suburban
1976 Blazer
