Old 05-03-2013, 11:46 AM   #26
shawno72
C/10 junkie
shawno72's Avatar
Re: pinion angle @ ride height
Is it only over 5o mph? Any vibes on take off or hard acceleration?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 05-03-2013, 12:00 PM   #27
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
None
Sick5 is offline   Reply With Quote
Old 05-03-2013, 12:19 PM   #28
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Funny things is ive been having this issue before a change my front end to dropmember.
When I drove to LA both times it ran with no issue then I was slowly starting to get this issue.
Could It be a ujoint or carrier bearing?
I have a small amount of play in the carrier bearing but the rear ujoint has no play
Old 05-03-2013, 12:31 PM   #29
shawno72
C/10 junkie
shawno72's Avatar
A center carrier bearing that has play will vibrate..
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 05-03-2013, 01:22 PM   #30
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
hmmmmm
well i guess im going to have someone take a look at it. first before a change it.
Old 06-09-2013, 07:43 PM   #31
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
where do i place the angle reader on the tranny to get a true angle reading?
Old 06-09-2013, 08:27 PM   #32
Robznob11
Robznob11's Avatar
I pull the yoke off and stick it to the face of the output shaft
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-10-2013, 12:12 PM   #33
69gmcc10
69gmcc10's Avatar
Same here
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 06-11-2013, 08:49 AM   #34
wraprail
wraprail's Avatar
You can also use the starter pad or the pan rail if you want to leave the driveshaft installed.
BTW, Its not "common practice" to just dial in 2 degrees of pinion angle in case the pinion angle just happends to change.
On a street car not using leaf springs, there is no axle wrap.
wraprail is offline   Reply With Quote
Old 06-11-2013, 10:26 AM   #35
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i was hoping to leave the shaft in..
im confused
what is starter pad and pan rail?
i just need more detail..
Old 06-11-2013, 11:57 AM   #36
Robznob11
Robznob11's Avatar
Im amused at how many people believe that the pinon has no movement on a street truck! I guess bildings and bridges dont sway in the wind either. Why put extra clearance in an engine block everythings bolted tight right. So nothing should flex or contact. Its not a case of if it were going to move, the question is how much! And if you think it wont because its a street truck more power to you! anything underload will move or flex period!!
LED TAILS
Old 06-11-2013, 12:48 PM   #37
Hart_Rod
Hart_Rod's Avatar
Hart_Rod is offline   Reply With Quote
Old 06-25-2013, 09:38 PM   #38
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Here's my numbers
Tranny. 5
Shaft1. 3
Center 0 raised 2 inches
Shaft 6
Differential. 0.
Old 06-25-2013, 09:39 PM   #39
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Haven't tested yet
Old 06-26-2013, 03:58 PM   #40
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Shouldn't it look like this
Tranny 5
Shaft1. 4
Cent b. 0
Shaft2. 6
Dif. 3 0r 5
I keep reading that my differential needs to be 1 from the first shaft but level with the tranny ?
Old 06-27-2013, 07:58 AM   #41
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Fixed!!! Change my differential up by 3° match my first shaft 3° down
Old 06-27-2013, 08:01 AM   #42
shawno72
C/10 junkie
shawno72's Avatar
Yay!! Just in time for Brothers
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 06-27-2013, 08:13 AM   #43
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Lol nope not this year....=( no money...
Old 06-27-2013, 10:27 AM   #44
Hart_Rod
Hart_Rod's Avatar
Can you post some pictures?
Old 06-27-2013, 11:40 AM   #45
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
I'll try
