Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech
Old 05-27-2005, 07:37 PM   #1
krue
Designated A-hole!
krue's Avatar
FAQ Index thread
I am trying to index our FAQ's by topic with links in this thread to make finding threads easier w/o needing to search the whole board.
This is a work in progress so please be patient.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
krue is offline
Old 05-27-2005, 09:39 PM   #2
krue
Designated A-hole!
krue's Avatar
67-72 Door related FAQ's
67-72 Window Regulator Replacement
Bowtiebandits window regulator swap instructions
Vent Windows
Looking at A1 Electric Windows Any Input?
Tips on installing vent windows
73-87 Door FAQ's
73-87 Door Internal How To
88-up Door FAQ's
96 Chevy outside door handle
www.daveramsey.com
krue is offline
Old 05-27-2005, 09:47 PM   #3
krue
Designated A-hole!
krue's Avatar
FAQ's Paint and Body Related
Fireman Marker light location guide
HOW TO: Poor man's no-weld gas cap delete
Cab Bolt Hole Measurements
Blazer Side Molding with Wood Trim
Blazer body mount torque
Hinge pins
Safe way to install hood springs
Body swap
How to: Inner Rocker Panel Replacement by LFD Inc
Windshield removal tip
metal finishing pictures-no bondo repair
Truck Trim locations
MARTINSR's "Paint gun setup"
MARTINSR's Basics of Basics" - tool buying.
Martinsr's "What to look for in a paint and body shop"
Basics of Basics" Stainless trim repair / Metal finishing
Randy Ferguson's guide to welding sheetmetal
"VOC" has nothing to do with safety.
Trim removal
Repainting Blazer Top
GMCPaul's windshield install
Replacing body mounts
Rejuvenate your grille
Front clip removal how to
Cab mount replacement
Sport mirror mounting
More Basics
Martinsr's basics of fiberglas repair
MARTINSR's "Basics of Basics" Surface cleaners
MARTINSRs "Basics of Basics" Color choice
MARTINSR's "Template making"
MARTINSR's "Trial fitting of parts"
MARTINSR's "Paint Technology Basics"
MARTINSR's "Basics of Taping Jambs"
MARTINSR's "Basics of Body Panel Alignment"
MARTINSR's "Basics of Door Skins"
MARTINSR's "Basics of Body Filler"
MARTINSR's "Basics of bondo types"
MARTINSR's "Basics of Basics" MIG Welding
MARTINSR"S "Flat panel basics"
MARTINSR's "Basics of Stud Welders"
Martinsr's "Basics of Basics" Seam sealer
"Basics of Basics" rebuilding hinges.
"Basics of Basics" Color matching-Alternates
www.daveramsey.com
krue is offline
Old 05-27-2005, 11:58 PM   #5
krue
Designated A-hole!
krue's Avatar
General Message Board type FAQ's
how to join 'Clubs' on forum?
Screen saver link
How to post pictures, step by step instructions, using BB code
How to set up mIRC
General forum usage
Search
so ya like trucks eh?
Search
Help? need to resize this pic for my avatar
Message board lingo
Pic Posting
resizing pictures
Ebay search string
New Classified System FAQ
How to resize and post pictures
How to NOT delete the cookie for this board
FYI - Info on searching
How do I change my Log In Name?
Image and Video Hosting Sites
Message Board Lingo
How to Attach pictures to your post
Starting a New Topic
www.daveramsey.com
krue is offline
Old 05-28-2005, 12:10 AM   #6
krue
Designated A-hole!
krue's Avatar
Interior related FAQ's
Neutral saftey on van column
Tilt column How to install
Installed 70s/80s Cruise Control & It Works!!
YOU can paint your stock gauge panel (here's how)
My modified van tilt column
1967-72 Chevrolet Pickup Lock & Key Information
Gauge cluster
RESISTOR Location- Blower Fan HVAC
Neutral safety switch wiring
Tilt Column
New floor and sound padding
Swapping from idiot lamp dash to a guage dash
S-10 seatbelt modification
Rod's answer to :What is difference between blazer and truck bucket seats?
sevt___chevelle's interior dye/paint how to
Way to duplicate Glove Box option sheet
Lost ignition key? Fear no more. (A how to on fixing this)
LED Dash Conversion
Seacrow's bezel painting.
late model steering wheel & horn issues
Do-it-yourself custom kickpanels
Cheap security - LED install(PIC'S)
update on intermittent wipers
Gauges behind Bezel Install
Aftermarket Tach Install
Upholstery install instructions
camaro tach
Everything you wanted to know about van column install
Speedo Reset (Zero Miles)
Help with rebuilding a Tilt Column
67-72 Gauge Panel Removal
Want QUIETER Doors
Changing gages in truck (73-87)
Vinyl Dye how to
No-Weld Accelerator Conversion
Blower Speed Upgrade
gauge testing
39 steps to Farsides Bucket Seats
Ash tray springs (73-87)
Shortening Steering column
turn singal switch info
GENTEX temp/compass mirrors -- wiring
Restore 67 Wheel
Dynamat vs other
67-72 Printed Circuit Layout
fan control switch went bad
Gringoloco's Camaro tach install
www.daveramsey.com
krue is offline
Old 05-28-2005, 12:47 AM   #7
krue
Designated A-hole!
krue's Avatar
Brakes and Suspension related FAQ's
Borgeson Steering U-Joint Review.
Brake Proportioning Valve problems.
Lowering blocks 101
HOWTO: Power steering conversion (67-72 trucks)
2wd hd leaf spring bushings
replacing ''A" arm bushings &balljoint pics
Spring removal tips
C-notch step by step
Cadillac Eldorado-style caliper tech tip
Disc brakes. 73-87 on 60-66
67-72 Brake booster m/c guide
power steering add on
73+ Booster/ m/c on older trucks
Coil spring rear sway bar
Comprehenive C10 Drop Components Parts List FAQ ANSWERED
Swaybar Install FAQ With Pictures
easy disc brake swap
Lift kits for 2wds?
Fabbed up some front sway bar mounts(PIC'S)
Illustrated Air Bag Installation Guide
How to shorten a LWB frame
More Sway Bar Info
Sway Bar info
Lowering Methods and Information
DiscBrake/Tie-rod End/Interchange
Replacing upper "A" arm bushings and balljiont
71-72 Disc brake conv using 67-70 supp
Power Brake Conversion
How-to Change front brake pads
Frame Diagrams
Testing brake booster
Hydroboost
Lowering Blocks 101.....
www.daveramsey.com
krue is offline
Old 05-28-2005, 02:33 AM   #8
krue
Designated A-hole!
krue's Avatar
Engine and Drivetrain related FAQ's
Vacuum gauge chart
Auto tranny guide
350 TBI to a 454 TBI swap
Rear end gears
TBI Conversion
How to install exhaust passages in your t-arm cross member
Interesting Compression Ratio vs Cam Duration Rule of Thumb
Sbc Overhauling 123 Top To Bottom W Pictures And Commentary
Drilling Steam Holes For 400 Engines
Starting Truck After 15 Years
Poor mans plug wire separators
3 Speed Manual Column Shifter Adjustment
Installing New Valve Springs And Seals
sbc / bbc valve train adjustment
hot engine won't start
My hydraulic clutch and Hydroboost setup
Installing Screw In Rocker Studs & Guides
FAQ: Engine Overhaul Tools
Cam And Lifter Install/getting The Timing Right
vortec heads what to know
Oil change information
700R4 Conversion FAQ
Wheel bearing race removal
SM465 to NV4500 swap
Holley gurus come in and talk..
Small block Fuel pump replacement tips
Early Classic Gen III engine mounts
Big Block Motor Mounts on the cheap.
Non A/C Heater core R&R...Acording to Jewels.
How to adapt 73-87 engine mounts to a 67-72 frame
How to on axel ratios
Ogier's Caddy BB swap
350 and three on the tree
beating this question to death! LT1/4L60E
Auto tranny guide
Sealing the thermostat housing...
50 dollar electric fan swap
Adapting throttle rod to new carburetor...
Custom Kickdown for TH400...
Replaced my heater core! Lots of fun! Pictures!!!
Websites for engine decoding
Air FLow Research vs. Vortec on flow bench
TH 350 Tranny X-Member Fabrication
4X4 Manual to Automatic Transmission Conversion
Fan clutch check/insp according to 70blowngmc
rad hoses
Driveshaft Overhaul
500 Caddy engine transplant (from MOT)
tired of brake fluid dripping while doing brake work?
headers with stock AC
Edelbrock TS guide
Cooling System 101
Vortec & regular Head Rocker Stud Change
Small block head flow number comparison
Camshaft information from the north
Old school cylinder head information
Link to 205 exploded diagram.
identifying rear-ends
5.3L GenIII /TH400 swap
If you want to do a 5.3/4L60E install, lots of pictures and info.
Holley 600 Rebuild / Overhaul
5 speed conversion with pics
tranny measurments
www.daveramsey.com
krue is offline
Old 05-28-2005, 05:15 AM   #10
krue
Designated A-hole!
krue's Avatar
Wheel related
Wheel/Tire Fitment Pictures & Info
Stripping/polishing clearcoated aluminum
Later model 6-hole ralley wheels and Isuzu caps
71cadc10's backspacing explanation
List: Wheel Manufacturers
6 Lug rims that will fit on 67-70 trucks
Found a cool web site, tire sizes
Tire Manufacturer Codes
A/c related
How a/c works
Vintage air
Vintage air A/C installation
Old Air A/C installation
Finally got my A/C working(PIC'S)
Can I add factory AC?? Help!!
Rebuild your A/C controller
Keep Your Cool! Vintage Air Sure Fit Install in a 67 C-10
General info
1967-'72 Chevrolet & GMC Pickup, Key Blank Chart
67-72 Vin and model number break down
Insurance for the rest of us
map of texas salvage yards
73-87 Chevy Truck & Related-GM Part Numbers
Links
67-78 Dana axle bible
Post your GM part numbers here
FYI: TOW HOOK guide with pics
longhorn, cst, etc
73-87 Differences
Site for tech advice
Classic Insurance Companies
1970 Option list
GM restoration packet
1967-1972 Chevy Truck/Blazer/Burb/Panel Production Numbers
All you "frame off" guys.. got some ?????'s
Truck value guides
Standard and optional equipment listing....1968
Standard and optional equipment listing....1967
Shuttermutt's winter driving tips
back to the basics
GMC vrs Chevy fenders
Ca. Vehicle Registration fees
73-87 VIN Number
indented part number reading trick
After market bolt and screw kits
67 and 68-72 Ignition bezal/spacer details
Year Model Differences by Johnnyp
Tool related
Handy tool I made
Blazer top removal
Bed mounted winch
Homemade brake pressure bleeder
powder coating oven
Welders!
cheap engine cooker Acording to bisquik65
cab lift adapter for engine hoist
How I raised my (blazer) top to the roof
Cab Flip Made Easy
How to ID the 68 C-10's & C-20's that had Factory BB's
Out There
Shifty's guide to getting the girls
That's it for now.
www.daveramsey.com
krue is offline
